Hello with all My new MOD is called "virus" WHY THE MOD VIRUS? I wanted to create a new style of MOD, more modern, more futuristic one attack of the machines WHY THE NAME OF VIRUS? the name of VIRUS, comes from the film fine VIRUS left the Nineties, or a entiter invaded a vessel by the lines of transmission via a satellite, takes the control of data processing, and keep silent all the crew and reconstitutes it semi-men, semi-machines. The poster of film It will resemble this one a little http://forums.bit-tech.net/showthread.php?t=111576
"VIRUS" will be enough small for a PC of infiltration, therefore the élements will be micro atx as much as possible, the base will be rather simple to build aluminium and plexi. Here élements of "VIRUS" The micro mother chart atx, dd of 160 A left and has right the DVD, the food below From CM I will build the framework and thus the machine in any case will not be large 255mm of face limps it for dissucussion http://forums.bit-tech.net/showthread.php?t=111576
the lower part of VIRUS Here the face finally the chest With, an edge Armour-plates for the chest With the spacers Work has the small file for the completion, and always sandpapering à.fond Here the tete of "VIRUS" This is the remainder of the éssai of paste PLASTIROC of "SAMURAI" the éssai of face which I had put of dimensioned I cut with the dremel and aprés a good hour veiled the result for dissucussion http://forums.bit-tech.net/showthread.php?t=111576[/QUOTE]
Very interesting mod. Looks like you're specialiced in "faced" PCs haha. I think you would like the new toy of amstrad: http://www.amstrad.com/amsface/index.html
Remember the place in the movie where the captain of the ship makes an agreement with the aliens and then try to kill the humans?
hello Kumo and Co2 I thank you for your ideas, but "VIRUS" is already to finish, I has just begun my 3 MODS l"O.P.M.TT ". The face of "VIRUS" is a wink with TERMINATOR FILM CULTE.Au departure "VIRUS" was to be in the form of human, but the prices of the mannequins are trops expensive in France
hello everyone I improve the mask one can the mask The mask with teeth fixing of the chart mére and cutting of the arriere just the plate as well as the clamp holes that my taken more time than envisaged fine extra sandpapering and all the angles too But also my camera veiled photographs of the clavicles Here famous beams with the support for dd or dvd, all and out of aluminum except obviously the beams
Here work The support with its fixing Work with much of precision, but it is not finished one needs more details It is necessary that I it reserre Here the new photographs the ballanciers are almost finished It misses the clavicles
Hello thank you all that has gives me courage for the construction of my mods full home made but for VIRUS you will surprise others
Hello with all and Thank you for your messages sympathetic nerves. I AI The SOLUTION FOR MY CLAVICLES. Here the Result The kneecap is adjustable in height with retaining nut Center aluminum kneecap the spacers make 24mm of longor, with a filtée stem of 70mm and diamétre of 4mm which passes inside with small discs and écroux one-eyed For my solution of the beams which this levent, I simply curved the clavicles with a thermal decapor Veiled what that gives. The hatched parts will be cut out On the clavicles the green point corresponds has fixing Veiled the whole with the one-eyed ecroux, the fact that the clavicles either offset and slightly bent causes a rise of the beams of 100mm or of dimensioned or other following as one turns the tete to him
One sees well the kinematics of the clavicles in rotation exterieure A small NEWS, the construction of the low part of "VIRUS" ATTENTION BOTTOM IS NOT FINISHED The threaded rods will be used of slides, and adjustment A 480watt for "VIRUS" Here a sight of the unit "VIRUS" makes a height of 700mm
Man you have way too much time, and way too much skill Your plexi skills drive me mad... well actually, frustrates me... I want them too
Go hop a small update Veiled what I did, new the coxis with an end of plexi which was hidden unpleasant OH (le plexi) Thanks to the burner, now I can fold the plexi on the top of the food the small carriage is which will support the articulation of the bust of "VIRUS" it slides on two stems and possede of the springs which gives it in initial position I make my shock absorbers With you always tubes out of aluminum of the round out of aluminum and within the competences of brake of door I makes four of them that I couple by two for each with dimensions The next stage will be the assembly of the shock absorbers and the completions Veiled with shock absorbers of washing machine which I cut into two I could make fixings of the BUST on the TRUNK The spring of the armortissor will go in the medium and will perméttera better an elasticity of the unit As usual the whole in corniere of 20*20 frosted of the two with dimensions ones The coxis broke when it fell, therefore I cut out the part in question and remoulds the unit It will be necessary that I attack myself this dimensioned there too That passes just and does not rub on the alim of 480
:bounce: Here "VIRUS" in situation. Of face Same the bust I GO WHEN SAME ALLEGER the WHOLE BY DRILLINGS OF LARGE DIAMETER The HEIGHT OF "VIRUS" EAST OF 640MM AND WIDTH EXT. OF The BEAMS OF 580MM veiled the armour-plates de for the beams, protection against the shootings Plate aluminum, frosted and curved to take the shape of the beams
Hello virus will reellement have a true Web-camwood creative for the msn but especially I wanted that virus is of a new style of MOD really very different standard cases
