Scratch Build – In Progress Project HELIOS - Mod or Materials Sciences Class - You Decide - 4.27.11
Discussion in 'Project Logs' started by Langer, 18 Sep 2010.
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    HELIOS, the Titan god of the sun. Tireless is he who is like the deathless gods.
    As he rides his chariot, he shines upon men, and piercingly he gazes with his eyes from his golden helmet.
    Bright rays beam dazzlingly from him, and his bright locks streaming from the temples of his head gracefully enclose his far-seen face.
    A rich, fine-spun garment glows upon his body and flutters in the wind: and stallions carry him.
    Then, when he has stayed his golden-yoked chariot and horses, he rests there upon the highest point of heaven, until he marvellously drives them down again through heaven down to the lasting earth.
    Design Features:
    - Crafted from the worlds highest grades of composite materials and carbon fiber.
    - Showcasing some of the finest watercooling components and computer hardware.
    - Designed to hide every fastener, nut and bolt.
    - A lack of case windows leave the motherboard bare and exposed.
    - High-tech and specially engineered ceramic foam filters and stainless steel mesh keep out dust.
    - Made from virtually indestructible panels over 8MM thick.
    - Taking advantage of air pressure zones to keep hardware dust-free.
    - Fully removable motherboard tray without disconnect or power-down.
    - Highly modular design makes part-swapping as simple as possible.
    - Sleek minimalist design is a call back to swiss modernism and bauhaus principals.
    - Design and fabrication methods tailored to an extreme rapid fabrication cycle.
    - HELIOS is to be a scratch build mod, truly, like no other.
    Hardware List:
    Computing:
    Processor - 1x unknown
    Graphics - 3x nVidia GeForce GTX 480
    Motherboard - 1x unknown
    Memory - 12GB unknown
    Power - Corsair AX1200
    Storage - 8x 120GB SSD
    Display - 3x Asus VW266H 25.5"
    Cooling:
    Processor - 1x AquaComputer Cuplex Kryos XT
    Graphics - 3x unknown
    Radiators - 2x HW Labs GTX420 (3x140mm)
    Tubing - 20' Tygon AS600038
    Fans - 13x NB-BlackSilentPro PK-3
    Pumps - 4x Laing DDC-1plus
    Pump Tops - EK-DDC Dual Top V2
    Memory - Mips RAM Kühler6
    Fittings 1 - 10x 3/8" Straight Rotary Fitting
    Fittings 2 - 20x 3/8" 45 Degree Rotary Fitting
    Fittings 3 - 20x 3/8" Angle Rotary Fitting
    Fittings 4 - 10x Low-Profile Stop Fitting
    Fittings 5 - 16x Fitting Spacer
    Fittings 6 - 16x Mini Fitting Spacer
    Fittings 7 - 8x No-Spill Quick Disconnect Female
    Fittings 8 - 8x No-Spill Quick Disconnect Male
    Fittings 9 - 4x 2-Slot Crystal Sli-Link Tube
    Fittings 10 - 3x Mini Sli-Adapter
    Fasteners and Hardware:
    Polyethylene Spacer - 40x 3/16”OD x .115”ID x 3/8” (McMaster - 92825A009)
    SS Dowel Pin - 50x 3mm x 6mm (McMaster - 91585A051)
    SS Press-Fit Threaded Insert - 5x 1/4-20 x 1/2” (McMaster - 92394A116)
    SS Press-Fit Bushing - 4x .257”ID x 1/2”OD x 1/4” (McMaster - 8492A155)
    SS Knurled Thumb Screw - 4x 1/4-20 x 3/4” x 1” (McMaster - 91830A577)
    Wool/Rayon Adhesive Back Felt - 1x 24” x 32” x 3/64” (McMaster - 8770K3)
    SS Low Head Socket Cap Screw - 75x M4 x 30mm (McMaster - 92855A425)
    SS Knurled Thumb Screw - 24x 6-32 x 1/2” x 1/4” (McMaster - 91746A536)
    SS Low Head Socket Cap Screw - 25x 6-32 x 3/4” (McMaster - 93615A210)
    SS Self-Lock Flat Head Cap Screw 25x 10-32 x 1” (McMaster - 92805A268)
    SS Male-Female Standoff - 18x 6-32 x 3/16”OD x 3/16” (McMaster - 91075A461)
    Hinge / Lid Support - 2x 1.744” x 5.313” (McMaster - 14785A51)
    Materials:
    - 8MM thick CNC cut carbon composite panels crafted to the strictest military specifications
    - 2MM thick thermoset carbon composite panels made for aerospace applications
    - Stainless Steel hardware throughout
    - Stainless Steel micro-weave mesh
    - Felt dampening
    - Polyethylene to reduce friction in modular areas.
    - Custom engineered ceramic foam air filters
    Specifications:
    Size - 206mm Wide - 610mm Tall - 610mm Deep
    Weight - unknown
    Performance Statistics - unknown
    Design, Prototypes, Mockups and Fabrication log to follow.
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
  3. Langer
    Langer Jesse Lang
    24 Jan 2004
    Current Progress
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    INITIAL CONCEPT ILLUSTRATION:
    Using Adobe's Illustrator I created a couple rough perspective drawings, so that I could get a better idea of the concept in my head:
    -At this point the plan was to construct the case in Aluminum.
    REVISION 1.0:
    REVISION 2.0:
    After talking with the community and doing some more planning myself, I made some changes to the plan.
    -Altered some of the chassis dimensions.
    -Trashed the idea of stacked radiators.
    -Relocated the pumps and reservoirs.
    -Added a downward facing PSU fan, which would later be scrapped.
    -Finalized the tubing layouts.
    -Changed from 360MM radiators to 420mm
    -Changed the fabrication material to Grade 38 Titanium
    REVISION 3.0:
    I again posted my designs for the community to critique and made some very minor alterations yet again.
    REVISION 4.0:
    At this point I was getting some really good feedback online and started putting it into practice.
    -I redrew the entire design with new dimensions.
    -Plotted the wiring paths.
    -Refined the tubing layouts.
    -Finalized the pump and reservoir positions
    PAPER PROTOTYPE:
    It was now that I decided to take my design and bring it into the physical plane. The medium I decided upon was cardboard and tape - the board I used is the same stuff one would use to matte pictures when framing.
    REVISION 5.0, current and FINAL revision:
    Happy with the prototype and the general concept, I decided it was time to finalize the plan and fix the little issues. This revision I've kept to myself until this now. I've made many very small changes to the plan.
    -I again completely redrew the design, this time with 8MM thick paneling.
    -I added small routered grooves where the panels fit together to better hide the seams.
    -Altered the relationships of components and their positions.
    -Finalized the design for the PSU cavity.
    -Beveled all the edges of the cuts - to compensate for the diameter of the 1/8" cutting tool on the CNC router.
    -I also swapped out the Titanium for a Carbon Fiber construction instead (I'm going to save the Titanium I acquired for another project down the road).
  5. Langer
    Langer Jesse Lang
    24 Jan 2004
    I've been working with an engineer, and friend of mine named John Dalton, who has graciously offered up some time to throw together a 3D mock-up.
    He sent me off the first revision of his model today.
    There are couple of minor errors, due to my vague explanations:
    -In this model the motherboard backplate is flipped 180deg
    -The SSD mounts are affixed to the side panels instead of the rads
    -the motherboard tray is just floating in space.
    They are such minor issues that I have no problem at all sharing some previews with you.
    And John already agreed to rectify the issues for me on Monday.
    You can CLICK HERE for a live model preview which you can rotate around and navigate in 3D space.
    Unfortunately this HTML export from SolidWorks is only supported by IE, and on PC.
    Here's an ISO view with perspective.
    Side view with perspective:
    View of the back and side of the chassis.
    A couple of detail shots of the bottom.
    Note here how I managed to save some space by routering out some spots in the chassis and side-panel. These will allow for a couple extra millimeters for the pumps and PSU fan.
  6. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Sold! Subbed and you haven't even started. That sounds like my kinda style.
  7. Langer
    Langer Jesse Lang
    24 Jan 2004
    That's all I have to share for today.
    I'll have the revised model as well as some renderings to show you all next week.
    As well, next week, I'll share some pictures of the manufacturing process behind the composite panels. Perhaps even some shots of them being CNC cut to spec.
    *j
  8. miikrr
    miikrr What's a Dremel?
    18 Sep 2010
    I see you said you're saving the titanium for another project. Does that mean you wont be making a one-off version of this case with titanium?
  9. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Titanium ? Isn't titanium a bitch to machine ?
  10. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    oh yeah it finally starts! I can't wait to see the process. And also this is the best planned mod Iv'e seen ever! Hope everything will turn out as planned. Subbed.
  11. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Now where did I see this before. hmmm... No matter, it looks sweet. Glad to see this in the building stage. Sub'd :D
  12. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Did I read 8 120 gb SSD?
    in RAID 0 that must be monstrous.
    Nice design having the Mobo in middle with sleek clean case around seem hot.
  13. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Water can cut anything :D
    I can already see this being a mdpc winner.
  14. DeltaFX
    4 Aug 2006
    Indeed, water does. But water doesn't work very well for milling.
  15. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Wow, you've put alot of work into designing this. This is gonna be one heavy case.
  16. amagriva
    amagriva Minimodder
    13 Jun 2009
    Me too: Prometheus Start 18th Jul 2008, 00:17 - End ???:eyebrow:
  17. Langer
    Langer Jesse Lang
    24 Jan 2004
    @miikrr - Thanks for signing up mate, and welcome to BT. And, yes you're correct in your comment.
    @DeltaFX - That's why we have lasers and machine shops.
    @Razer2007 - Thanks boss. I'm very excited to get this one wrapped up finally.
    @LooseNeutral - =)
    @Fabou - Muahaha! Thanks a lot man.
    @llamafur - Thanks a lot for the vote of confidence.
    @riekmaharg2 - The panels are featherweights compared to a metal alternative... but it's still going to be a beast on the scales. Thanks for the comment.
    @amagriva - I don't have a place to live and call my own, so the nearly complete Prometheus will stay in a box until I do. But it has come a LONG way since it was seen last... that'll be a surprise for another day.
  18. Razer2007
    18 Jul 2010
    Am I boss?
  19. Langer
    Langer Jesse Lang
    24 Jan 2004
    Boss, buddy, guy, dude, mate, man, bro... I'm trying to mix it up a bit. ;) lol
  20. Mork
    Mork What's a Dremel?
    9 Nov 2009
    Langer, WHY are you so awesome?? - Is it a special diet or something that makes you so awesome? :D
    Anyway, I'm really looking forward to seeing this one come along! :thumb:
    Subbed and in love :p
