Lian-li v1100 16 June
Discussion in 'Project Logs' started by J0d3r, 12 Mar 2006.
  1. J0d3r
    J0d3r What's a Dremel?
    13 Sep 2005
    Hi,
    I'm currently working on a Lian-li v1100, the "untouchable" modding case :dremel: .
    Please, post your comments/opinions here
    Thats my 3r mod, I would thank to moddingrafia.com to give me sponsorship and work in a airbrush design for the case.
    Well, lets introduce the case:
  2. J0d3r
    13 Sep 2005
    Thats de design of the side:
    Now I will polish the stand.
    And finnally thats how it will look the floor:
    regards ^^
  3. J0d3r
    13 Sep 2005
    Hi, new update!
    The next step is cover that:
    For it I'll use that:
    Regards
  4. J0d3r
    13 Sep 2005
  5. J0d3r
    13 Sep 2005
    Well, I'm working all the morning at these:
    1º: The 12cm fan that will give air to the HD, do you know where they will fit?
    2º: I start working on the acrylic panels, sanded them, and drilled:
    3º: finnally thats how it looks:
    Please, let me know what you think :)
    regards
  6. J0d3r
    13 Sep 2005
    Well, with that i stop for today
    Please tell me your opinion
    saludos
  7. J0d3r
    13 Sep 2005
    Hi!, not a really update, only a few new photos about the 12cm new fan
    Today I will buy a few aluminum and make the HD rack and something more :p
    Saludos :D
  8. J0d3r
    13 Sep 2005
    Well, im working all the evening in the HD rack, I bought too a mesh, and I fitted the alu that divides in two the case again and well... thats the photos :p
    Lets start with the mesh:
    Luego hemos remachado la plancha a la torre de nuevo:
    That will be the rack:
    Work to do:
    And finnally a few pics of the installed unit
    Saludos :)
  9. J0d3r
    13 Sep 2005
    A new update, please check the worklog here
    regards
  10. J0d3r
    13 Sep 2005
    Hi!
    I`ve got a raptor from my 1º PC and test how the rack works (remember that I have to do the upper part of it), seems that all fits good.
    The cables will fit in the HD by the frontal side
    What do you think?
    saludos
  11. J0d3r
    13 Sep 2005
    Hi!
    Other small update:
  12. J0d3r
    13 Sep 2005
    Hi!
    I was trying to find carbon fiber adhesive here in Castellon, but i didnt found it :(, btw i used Aeronfix, and thats the result:
    saludos
  13. J0d3r
    13 Sep 2005
    A new sponsor has come! thanks CoolMod for your help ^_^
  14. chardo
    chardo What's a Dremel?
    26 Nov 2004
    Well work!!
    I don't understand why have you used aeronfix. What do you want to obtain? darker black perhaps?
    Greatings
  15. J0d3r
    13 Sep 2005
    Hello
    Yesterday I was at local store gettin some modding fun:
    Its aluminum, mesh, allen screws, and other stuff:
    Well, now its time to work with the alu, first of all I protect it:
    After making the drivebay cover with alu (no photos :sad:) I started bulding the upper part of the HD rack:
    I mark where to cut and where to bend:
    Now cut and blend hehe:
    And finnally we drill and screw up the racks
    And thats all:
    regards ^^
  16. J0d3r
    13 Sep 2005
    Hello, some new work:
    Saludos :D
  17. J0d3r
    13 Sep 2005
    Hello, new photos:
    And finnally I want show you the way I would pass the watercool between the two zones of the case. At the imposibility of getting pass-a-way connectors here, I used two racors and a screw to fit it all in once:
    I wanna chrome that for best looking. Plz remember the discussion thread: http://forums.bit-tech.net/showthread.php?t=109369
    Saludos
  18. z4114
    z4114 FACE!
    25 Jun 2002
    That's a slick looking etch on your acryilc. Did you do that yourself or source it out somewhere?
  19. The Bart Man
    The Bart Man What's a Dremel?
    27 May 2004
    Great looking case. A was planing a mod with the same case only with the new lian li case releases I will first check those out.
    But good modding, nice way to work "ugly" places away.
    Keep up the good work. :dremel:
  20. alastor
    alastor Minimodder
    6 Sep 2004
    Looking very nice so far, just one question though: if you're going to put the PSU in the bottom where it belongs, how will you get the power cables through the divider?
