Modding Project: DIY CNC - V3 Reinforced Z Axis
Discussion in 'Modding' started by lenne0815, 16 Dec 2009.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    I mentioned it before a couple of times already im was planning to build an diy cnc.
    My inital specs for the machiene are:
    capability of routing up to
    - 19mm mdf / whiteboard
    - 5mm aluminium
    - ~700 x 700 mm working area
    - 3 controlable axles (for now there wont be a 4rth axis to tilt the router itslef, maybe i add it later for complex 3d shapes)
    - minimum room requirement ( therby it has to work like one of its bigger brothers, the workpiece itself wont move, complicating the build further)
    To make it a bit clearer here is an simple skp drawing showing the basic shape of the cnc:
    Green are the linear rails and the spindles, red are the stepper motors.
    After coming back to germany i needed some time to set myself up again, but now i got all the bits and pieces together, so yesterday i could actually start building it !
    right now the cnc consists of a makeshift table / baseplate ( ikea second hand store is my friend ) , mounted linear rails for the first axis and parts of the actual tool holder.
    Today ill try to mount the whole upper part, so expect more pics soon !
    pic of the mounted rails on the table
    Working on the lower part of the tool holder ( i know im messy, got too exited :D
    Close up on one of the runners
    Runners mounted
    One side of the lower part of the tool holder complete with mounted runners
    The whole thing
    closeup of the rails, already with the lower part sitting on them
    another closeup
    The whole thing in all its glory :)
    Nanosec likes this.
  2. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    Great Start !!!
  3. lenne0815
    4 Jul 2009
    I was freaking out that the whole thing jams on the linear rails, but after a lot of fiddling it runs smooth as silk :D
  4. stonedsurd
    11 Mar 2009
    That's pretty interesting. I'm really thinking of biting the bullet on one of these DIY CNC jobbies. But college leaves me with no bloody spare time :(
  5. -Acid-
    -Acid- What's a Dremel?
    10 Nov 2004
    how much are those runners????
    looking good so far
  6. lenne0815
    4 Jul 2009
    i got a set with 4 linear rails 800mm and eight runners, they were 200 euros ( pretty cheap considering they are usually around 90 euros per rail with two runners)
    i think the whole lot wil cost me roughly 800 in the end, but its the same as usual, without spending anything u dont get anything.
  7. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    I've often pondered,building a DIY CNC machine but never took the plunge so i'll be following this with interest,great start,subscribed :thumb:
  8. Cheapskate
    13 May 2007
    It's good that you have it up on a table. It's hell to oil the drive screw mounted under the table.
  9. lenne0815
    4 Jul 2009
    unfortunately, one drive screw will be under the table :D
    moar pics:
    Redone the mount for the lower part ( now adjustable and much easier to reach )
    drilling the "middle" plate which will later hold the short rails (300mm) for the tool
    closeup of the top part, already assembled with another 800mm set of rails
    another shot from the top rail assemply, now with the mounted middle part
    the lot
  10. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Looks good, personally I'd build it from aluminium profiles, but I guess it depends on what you intend to do with it.
    I'm not certain about this, but your linear components look very similar to these ones: http://myworld.ebay.com/linearmotionbearings2008/
    Are they any good?
  11. lenne0815
    4 Jul 2009
    dunno bout these, might be the same ?
    i would use aluminium profiles aswell, but proper ones are friggin dear...
  12. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Sub'd. If theres one thing I want, its homebrew cnc!
  13. Sleepstreamer
    23 Jul 2006
    Yes unfortunately, the cheapest ones I've found are from here: http://www.smt-montagetechnik.de/produkte/k-1.htm
    I'm currently planning to build myself a new & improved machine, since the one I have now is rather dated, so I'll def follow your build :)
  14. lenne0815
    4 Jul 2009
    what im planning later on when this iteration of the cnc is working to mill all the connection pieces and sandwich them out of - 5m alu + 10 mm multiplex + 5mm alu - with epoxy that should be rigid enough :D
    i checked ur link sleep but as i said, for me its just too dear :(
  15. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
  16. Nanosec
    28 Apr 2009
    + Rep ... I have added this thread to my subscription list mostly because not all the pics come out at work (where i read this forum most often) and partly because I want to make sure and not miss seeing it all come together
  17. lenne0815
    4 Jul 2009
    cheers mate :) somehow bit tech is like one of these addictive mmos, im such a rep whore :D anyway, today i wanted to reinforce the main table and mount the top part, but its really freezing here right now ( -7c ) and snowing like hell, my small workshop isnt heated, so maybe i skip today :(
    I decided to redo the smaller top plate, first time i did it came out too crappy cuz i didnt have spade bits to properly countersink the holes...
  18. bfelda
    bfelda ____
    28 Jun 2009
    Great Project
    Most diy CNC projects only cover small area's. This larger design is what I have been looking to see built. I wonder if the wooden components will keep the noise down a bit. Great project and thanks for sharing!:thumb:
  19. lenne0815
    4 Jul 2009
    After having too much time to think about my project and no time to actually work on it ( moved, bought car, found job etc etc ) i decided to completely redo the design again.
    My new design will be mainly based on 45x45 bosch aluminium system profiles, because to be honest it would work the way i started, but the lack of overall rigidity would cause mayor problems later on :( so heres a quick update on how it will look:
    the profiles and brackets will roughly be another 200 euros, but i really think itll be nesessary..
  20. Sleepstreamer
    23 Jul 2006
    Good call I'd say, these changes will make it so much more usable.
