#1 |
Modder
PC crashes when accessing network
Okay so here's the crack:
My PC seems to completely lock up when accessing files on my network, or doing a speedtest. Just completely freeze, music stops playing; the lot. I can play games for hours, stress tests are no problem either. I've tried running Windows Memory Diagnostic on full, doing 4 passes and didn't find anything. Moved from 7 RC1 to a full RTM version which still didn't fix anything. Any ideas? Cheers. |
#2 |
Modder
I should also add this is via Ethernet to a router, plus I can download from the Internet at 6MB/s without any problems.
#3 |
mother into a board?!
Do you have the latest wireless card drivers? How about motherboard? and BIOS? What is the Ethernet card processor you use (Broadcom, Nvidia, Intel, etc..)
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro! |
#4 |
Minimodder
Have you overclocked your computer in anyway?
__________________
| i920 D0 @ 3.8ghz | Noctua NH-U12P SE | Gigabyte EX58-UD5 | 3x2GB OCZ Gold 1600Mhz | Gainward GTX260 GS 655/1250 | InWin Commando 850W | Samsung F3 | Antec P180 | Samsung T200 20" | |
#5 |
Modder
This is via Ethernet. So I have my wireless card disabled. Atheros is the chipset, on a Asus P5K motherboard. I did try getting the lastest drivers..
But an odd thing happened, I can now upload without it crashing immediately, seems to happen after a short period of time. :s |
#6 |
Modder
#7 | |
Did you try the troubleshooting, steps that I suggested? Did it help? If not contact ASUS for tech support. You may need to RMA your board, and hopefully get a working refurbished one.
__________________
| Thread Tools | |
