RSS
Old 8th Nov 2009, 20:53   #1
gingbeard
What's a Dremel?
gingbeard is on a distinguished road
PC fan oil
Ok, so here is a good question - What is the best oil to use to libe up those dusty PC fans? Hair clipper oil?
gingbeard is offline   Reply With Quote
Old 8th Nov 2009, 21:50   #2
bigsharn
Ultramodder
bigsharn's Avatar
bigsharn is just really nicebigsharn is just really nicebigsharn is just really nicebigsharn is just really nice
I'd just replace them... or use a vacuum cleaner
Some oils will eat through the plastic as well, so I wouldn't try any out at all
__________________
{Q6600}-{HD4850 512Mb}-{Hiper M 630W}-{Samsung F1 640Gb}-{Antec 300}-{4Gb Team Elite PC6400}-{ECS P35T-A}
{Nikon D80 w/ 18-55 and 50mm f/1.8}-{Lomo Smena 8m}
{LandRover G4 Challenge}-{MonsterRoller No Animal}
Originally Posted by Sir Digby View Post
The answer is alcohol, and if that don't work use more alcohol!
bigsharn is offline   Reply With Quote
Old 8th Nov 2009, 22:27   #3
kenco_uk
glourious bacon?
kenco_uk's Avatar
kenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to behold
I was told sewing machine oil worked well.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech
T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door."
kenco_uk is offline   Reply With Quote
Old 9th Nov 2009, 00:05   #4
stonedsurd
I'm not Sparta :/
stonedsurd's Avatar
stonedsurd has a spectacular aura aboutstonedsurd has a spectacular aura aboutstonedsurd has a spectacular aura about
Yup sewing machine oil is fine.
__________________
Project PC3 - a PC in a PS3! (While the old one is mothballed)
We're people who have the patience and know the pain of sleeving. And love it
Bit Tech is more than games and hardware - check out the mods too. Don't let modding die in Bit-Tech.net.
stonedsurd is offline   Reply With Quote
Old 9th Nov 2009, 00:42   #5
kimandsally
Minimodder
kimandsally is on a distinguished road
You have to strip the fan right down and take the fan impeller out of the frame then clean the shaft properly, it takes like 30 seconds you need a sharpe instrumant to peel out the plastic clip that holds it togther.
Then a small amount of any thin oil like 3 in 1 will do great, I take mine to pieces about every year and clean and oil them, my 120mm fans are 4 years old and still OK, I think they run nicer after the first strip down and oiling maybe they are run in?
kimandsally is offline   Reply With Quote
Old 9th Nov 2009, 00:57   #6
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
Gun oil would work nicely as well if you have any.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is offline   Reply With Quote
Old 9th Nov 2009, 04:31   #7
Elton
A Monitor Afficionado..
Elton's Avatar
Elton is a jewel in the roughElton is a jewel in the roughElton is a jewel in the roughElton is a jewel in the rough
WD4D?
Sewing Machine oil or Gun Oil works pretty well too.
__________________
EP45-UD3P|HIS HD4850 ICE-Q 4 Turbo @ 690/1090|4GB G.Skill DDR2-800 @ 844mhz|HAF932|Antec True Power Trio 550w|E8400@3.8Ghz FSB:421 Volt: Stock|Vortex 752(Heatsink)|Mitsubishi/NEC LCD1860NX
Other Build: ECS RS400-A|Prescott P4 @ 3.45Ghz|2GB DDR2 533|OEM ATi X1600XT|Dynex 430w|Some Random Case|Mitsubishi 20" Diamondtron Pro
Elton is online now   Reply With Quote
Old 9th Nov 2009, 07:43   #8
gingbeard
What's a Dremel?
Gun oil you day?Yes - got that! Lots of online threads say that WD-40 is the worst thing you can do - not good for the fan at all. Could this be true?
Old 9th Nov 2009, 11:21   #9
kimandsally
Minimodder
I would be bad if you just sprayed the fan with it hoping it will get in, if you strip the fan down as I have said to do then it will be fine just on the bearing surfaces.
If it gets on the plastic it will probably rot it eventually.
Old 9th Nov 2009, 15:03   #10
Krikkit
Don't panic!
Krikkit's Avatar
WD-40 isn't very good for this kind of thing, it tends to destroy any grease that's left. I suppose ideally you would just use axle grease.
__________________
Old 9th Nov 2009, 17:26   #11
Daedelus
Minimodder
Daedelus is on a distinguished road
Originally Posted by Elton View Post
WD4D?
WD40 is not a lubricant, it's a water displacer (hence the name)
Daedelus is offline   Reply With Quote
Old 9th Nov 2009, 18:48   #12
tk421
Idiot.
tk421's Avatar
tk421 will become famous soon enough
try a silicone-based paintball marker lube. the cheap stuff.
won't eat plastic, etch anodized aluminum, or anything like that.
also, dry graphite might work in a pinch, but wont last that long ...
__________________
:gamebox: e7400@3.5 (333x10.5)|MSI Neo3f(p43)|2x2gb pc6400|HD4850 (512)|1.6tb across 4 hdd|CM590|westie lcm-22w3|
tk421 is offline   Reply With Quote
Old 9th Nov 2009, 19:49   #13
Cleggmeister
Likes MS, dislikes Apple
Cleggmeister is on a distinguished road
This could be a good thread, I'd like to know how to "improve" my fans to lower noise etc...
Please could someone post an idiot's guid to stripping, cleaning, lubing and rebuilding a fan?
Many thanks,
Cleggy.
__________________
Asus P6T SE, Intel i7 920 D0, 3Gb Corsair Dominator, Inno 8800GT, Samsung F1/F3 drives, Win 7 Home Premium, beQuiet Darkpower 650w, Akasa Nero CPU cooler, Xilence RedWing intake fan, Antec 300 case.
Shopping list: SSD, ATI 5850, premium soundcard...
Cleggmeister is offline   Reply With Quote
Old 9th Nov 2009, 21:03   #14
capnPedro
Deaf forever to the battle's din
capnPedro's Avatar
capnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to behold
DOW-33
__________________
ASUS M4A785TD-M Evo | AMD Phenom II x4 955 BE | D-Tek FuZion
4GB Corsair XMMS3-10666 | Corsair TX650
Point Of View 8800GTX | EK FC-8800
capnPedro is offline   Reply With Quote
Old 9th Nov 2009, 21:07   #15
Krikkit
Don't panic!
Krikkit's Avatar
I may write one this week, but for now have a look here for a guide which includes stripping a fan. For lubing just oil the shaft (*snicker*).
__________________
Old 10th Nov 2009, 00:05   #16
Elton
Elton's Avatar
My bad.
For some odd reason I was looking at a container of gun oil, and even worse thought it was WD4D..
Need to label my stuff..
__________________
Old 10th Nov 2009, 12:28   #17
tk421
Idiot.
tk421's Avatar
Originally Posted by capnPedro View Post
DOW-33
no, no DOW 33 or 55, or hater sauce, or any expensive lube. a $3 bottle of spyder or tippman oil ... or gold cup gun oil if you already have it.
i'm sure the DOW would work, but it would involve tearing down, greasing, and rebuilding. the oils, 1 drop, good to go
__________________
Old 10th Nov 2009, 21:06   #18
capnPedro
capnPedro's Avatar
My bad. 1/4 oz of DOW-33 is like $2 and is made of silicone so I thought that was what you were talking about.
__________________
Reply
Tags
fans, lube, oil, pc fans
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
