RSS
Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 27th Nov 2009, 18:06   #1
krazykid035
Entrepreneur
krazykid035's Avatar
krazykid035 is on a distinguished road
OCZ 6GB with i7 920?
I will have an intel i7 920 processor with an asus p6t D motherboard and want to know if this is a good RAM choice. I am going to get 2 kits to have 12 GB total.
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3P1600LV6GK - Retail
http://www.newegg.com/Product/Produc...82E16820227381
krazykid035 is offline   Reply With Quote
Old 27th Nov 2009, 18:10   #2
bagman
I *am* a Dremel
bagman's Avatar
bagman will become famous soon enoughbagman will become famous soon enough
that ram will be fine but i recomend that you only buy one set as 2 sets can limit your overclocking ability and very few people need 12gb ram spend the money on something else
__________________
vote for bit-tech here!!
bagman is offline   Reply With Quote
Old 27th Nov 2009, 18:15   #3
Jasio
Made in Canada
Jasio will become famous soon enough
I'd suggest either Corsair or Patriot RAM. I originally bought a 6GB OCZ kit for my i7 920 and P6T v2 motherboard and the OCZ RAM was crap -- never ran at rated speed or timings. OCZ claimed it was an Asus issue -- I wasn't sold on that really, I swapped it for a Patriot kit for $10 less that's been running without a single hitch. I've *always* had problems with OCZ RAM and Asus motherboards. After 3 attempts I don't plan to go back to them.
__________________
[[Asus P6T | Intel Core i7 920 @ 2.67Ghz cooled by Noctua UH-P12 Push-Pull Config | 6GB DDR3-1600 Patriot Viper Xtreme XMP C8 | nVidia GeForce 280 GTX 1GB | Corsair HX620 620 Watt PSU | Antec P182 Case]]
Jasio is offline   Reply With Quote
Old 27th Nov 2009, 20:05   #4
krazykid035
Entrepreneur
Hmm, I see what you mean now after reading some more reviews.
How about this kit:
CORSAIR DOMINATOR-GT 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model CMG6GX3M3A2000C8 - Retail
http://www.newegg.com/Product/Produc...82E16820145255
Old 27th Nov 2009, 20:52   #5
Sh0cKeR
hc/w=hf=e
Sh0cKeR is on a distinguished road
Dominator GT is overpriced, but its a 2000MHz Dominator kit so its a monster. You can save quite a bit of cash by going with the less expensive 1866MHz kit as thats more than enough.
__________________
Core i7 920 D0 @ 3.5GHz , Titan Fenrir /./ EVGA GTX 285 SuperSuperClocked -SLI- /./ Asus Rampage II Extreme X58 + Supreme X-Fi /./ Corsair Dominator 6Gb @ 1758MHz CL 8 9 8 20 /./ WD Velociraptor 300Gb /./ 1Tb Samsung Spinpoint F1 /./ Enermax Revolution 85+ 1050w /./ Antec 900 V2/./ Dell 2209WA, 2408WFP /./ Creative Sound Blaster Arena Headphones /./ Razer Copperhead, Roccat Kone /./ Logitech Z5500 /./
I modded a Womble
Sh0cKeR is offline   Reply With Quote
Old 27th Nov 2009, 22:22   #6
Jasio
Made in Canada
For best compatibility, and cost effectiveness I'd stick to DDR3-1600Mhz. Anything from Corsair will be fine. Patriot Viper is great too.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
