RSS
Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 27th Nov 2009, 18:44   #1
Turbotab
I don't touch type, I tard type
Turbotab's Avatar
Turbotab is a name known to allTurbotab is a name known to allTurbotab is a name known to allTurbotab is a name known to allTurbotab is a name known to allTurbotab is a name known to all
Add more ram but lower overall speed, what to do??
Hi Y'all,
I currently have 4 GB of Corsair XM2 DDR2 1066 ram, I've been given a 2 GB module of 800 MHz. Is it worth adding the extra 2 GB to create 6 GB of ram, but at the cost of lowering overall ram speed down to 800 MHz? I use the PC for general purposes, gaming, work and watching movies etc, but no real memory hog tasks.
Turbotab is offline   Reply With Quote
Old 28th Nov 2009, 08:12   #2
MaverickWill
Dirty CPC Mackem
MaverickWill's Avatar
MaverickWill is a splendid one to beholdMaverickWill is a splendid one to beholdMaverickWill is a splendid one to beholdMaverickWill is a splendid one to beholdMaverickWill is a splendid one to beholdMaverickWill is a splendid one to beholdMaverickWill is a splendid one to behold
Quick question (and it might be a daft one) - what OS are you running? If it's 32-bit, it won't make a difference to capacity, but will knacker speed.
As far as 64-bit goes, even Crysis doesn't need 6GB. Unless you start hammering Photoshop on a regular/heavy basis, I wouldn't. Course, if you overclocked, you might be able to get all 3 sticks running around the 900-ish MHz mark, or higher with slacker timings. Just a thought...
__________________
Originally Posted by Combatus
I thought I'd give them all a good rub down before sending but it's actually massage oil, delicately placed by my firm fingers in an attempt to make them look and feel perfect just for you!
Enjoy!
MaverickWill is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
