#1 |
Multimodder
Graphics card length/power reqs
I'm currently running a bumped-up prebuilt system- I replaced the PSU with a pretty no-name 500 watt (Zumax? I got it for $50, so I don't think it's exactly brimming with quality) and put a 9800 GT in the PCI-E slot.
What's the best graphics card that can be powerd on a 500 watt PSU with one 6-pin? (Also, I need to measure my case to find the longest card that would fit.) |
| she'shighvoltage! |
| View Public Profile |
| Find More Posts by she'shighvoltage! |
#2 |
Wetsander
For that matter, could we compile a list of GPU card lengths, and have it stickied?
| Sparrowhawk |
| Find More Posts by Sparrowhawk |
#3 | |
A Monitor Afficionado..
Currently, I'd say the HD5770.
__________________
#4 |
Multimodder
I was thinking along the same lines.
I need to get a ruler out and measure my case, though, I might be able to fit a 5850 if I get a new PSU as well. |
| she'shighvoltage! |
#5 | |
Incidentally, what is your PSU?
__________________
#6 |
Multimodder
| she'shighvoltage! |
#7 |
I'm not insane I'm a modder
| grritsshawn |
| Find More Posts by grritsshawn |
#8 | ||
You can always try to hunt for a HD4890, which still has plenty of stock, but it'll need 2 PCI-E power pins, and is pretty hungry in terms of power. You can push a HD4890 on that,but you'll need a molex--> PCI-E connector, and there might be the problem of overloading your PSU if it's a cheap one(never heard of Zumax).
__________________
#9 |
hc/w=hf=e
You managed to find a PSU with one six pin PCI-e?!. From that I doubt its output is anywhere near 500w anyway...
__________________
Core i7 920 D0 @ 3.5GHz , Titan Fenrir /./ EVGA GTX 285 SuperSuperClocked -SLI- /./ Asus Rampage II Extreme X58 + Supreme X-Fi /./ Corsair Dominator 6Gb @ 1758MHz CL 8 9 8 20 /./ WD Velociraptor 300Gb /./ 1Tb Samsung Spinpoint F1 /./ Enermax Revolution 85+ 1050w /./ Antec 900 V2/./ Dell 2209WA, 2408WFP /./ Creative Sound Blaster Arena Headphones /./ Razer Copperhead, Roccat Kone /./ Logitech Z5500 /./I modded a Womble
#10 | |
Hypermodder
__________________
Icarus: Retired Ragnarok: i5 750 | MSI P55-GD65 | 6GiB Patriot 1.6GHz CAS 8 RAM | 512MiB 3870 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win7 Pro | Ubuntu |
| storm20200 |
| Find More Posts by storm20200 |
#11 |
Multimodder
I'm wondering how much my PSU can actually spit out...
Well the Bit-Tech charts says the 5770 is shorter than an ATX mobo and also eats up less power than the 8/9800 GT I'm running, so I think I'll be fine aiming for one. |
| she'shighvoltage! |
#12 |
hc/w=hf=e
I was meaning the total output, not just the 12v. Hazard a guess and its more like a 350-400 psu than a 500.
__________________
#13 |
What's a Dremel?
I would definitely agree that with that power supply since the true voltage output is probably a great deal less than advertised you would probably be happier getting the 5770, I have one and its an awesome card and its tiny (a lot smaller than the x1900 it replaced) and since its using a smaller nm chip its a LOT less power hungry than other cards.
| Thread Tools | |
