RSS
Old 28th Nov 2009, 00:32   #1
Zener Diode
User Title
Zener Diode is on a distinguished road
X.M.P.
Hello everyone.
I built my first PC a while ago, these are the parts:
Motherboard: Asus P6T SE
RAM: Corsair DDR3 XMS3 6GB @ 1600MHz
GFX Card: NV GTX 260
Case: CM HAF 932
CPU: i7 920
HDD: WD Caviar Black 640 GB
CPU Cooler: Titan Fenrir
PSU: Corsair HX 750
Now, I have tested the X.M.P. RAM profile and I did notice a performance increase. The thing is that I am not keen on overclocking for a number of reasons, so I want to know, is X.M.P. a very stable overclock setting and will it have a significant impact on the life of my components? Also, since it is "Intel X.M.P.", will it void the CPU warrenty.
Thanks.
Zener Diode is offline   Reply With Quote
Old 28th Nov 2009, 00:40   #2
Von Lazuli
I get by fine with a jig-saw.
Von Lazuli's Avatar
Von Lazuli will become famous soon enough
XMP are just inbuilt settings designed to run the RAM at the speeds it was designed at. They should be very stable unless the RAM itself is faulty.
Also, it is impossible to tell whether or not a processor has been overclocked (ok, burnt out from LN2 sessions with 1.8v or something might leave a mark...). Thus, cannot void your warranty. You are not overclocking the processor anyway, just the RAM.
Laz
__________________
Working on: Shattered Horizon (November MOTM Nominee)
Von Lazuli is offline   Reply With Quote
Old 28th Nov 2009, 21:18   #3
Zener Diode
User Title
Thank you. I will enable it right away.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
