RSS
Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 22nd Jun 2002, 21:43   #1
delbert
Modder
delbert is on a distinguished road
Curved Plexi Case
It is not quite finished, but as little time as I have had to work on it I figured I had better show it now before it looks like an Intel 486SX. Credit to Linear where it is due. Imitation is the best form of flattery.
delbert is offline   Reply With Quote
Old 22nd Jun 2002, 21:44   #2
delbert
Modder
And powered up.
Old 22nd Jun 2002, 21:48   #3
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
WOW.. nice!!
Bindibadgi is offline   Reply With Quote
Old 22nd Jun 2002, 21:53   #4
BradfordPimp
Supermodder
BradfordPimp's Avatar
BradfordPimp is on a distinguished road
that IS very very nice
I'm thinking of building a very small lan box myself, out of aluminium, can you tell me what motherboard and cooler that is please? I'd love you forever
BradfordPimp is offline   Reply With Quote
Old 22nd Jun 2002, 21:55   #5
KypD
Multimodder
KypD's Avatar
KypD is on a distinguished road
d00d, that rocks! very nice looking, especially when lit up. i'm surprised you got it all in that tight space!
and, just so i can get it in before anyone else "can you do it bl00?"
__________________
Well glory be, the funks on me, Bubba G;
Keep that funk alive!
Well uh, back in 1975, we're just trying to keep that funk alive.
Do that funk!
KypD is offline   Reply With Quote
Old 22nd Jun 2002, 22:20   #6
delbert
Modder
It is not that full inside. It is a Shuttle FV24 with a 1 gig celeron CPU. It is a secondary (kids) computer that I use to watch TV in the office. I have a firewire CDRW connected to it that sits on top of my main computer under the desk. I did have a stripped down ATX power-supply inside but when I found a 1U rackmount PSU and started to strip it down to fit I decided to leave it external to help the heat and space issue. I have a USB floppy drive if I need one of those. I could have been much smaller but I have a full size TV Tuner card that Had to go in.
Old 22nd Jun 2002, 22:25   #7
CriticalPoint
Multimodder
CriticalPoint is on a distinguished road
Me likes, I was going for small ordering my LianLi PC30, but that takes the cake. I love small, and portable, but not laptops for some reason. That is an incredible case, job well done.
__________________
Member of the Bit-Tech Dolphin team.
I have error checking inside.
Two plus two for me equals four.
What about you, Mr. Athlon?
CriticalPoint is offline   Reply With Quote
Old 22nd Jun 2002, 22:34   #8
Jamie
bit-tech Staff
Jamie's Avatar
Jamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of light
That is very nice! but red leds? blue is a must
That would make a very nice divx player for a tv
How did you bend the acrylic? strip heater?
__________________
bit-tech hosted by tsohost.co.uk
twitter | flickr | xbox live | last.fm | moot
Jamie is offline   Reply With Quote
Old 22nd Jun 2002, 23:20   #9
delbert
Modder
Used paint stripper type heat gun to bend plexi.
Especially after using a filter to make the VFD more blue I gave Blue LEDs strong consideration. In my experimentation it didn't glow plexi edges as dramatically. One problem is that Blue LEDs are so focused. These red ones Im using have a nice wide angle along with brightness to spread along all the edges. However now that the red ones are in and the effect is more dramatic than I imagined Blue probably needs another shot.
Old 22nd Jun 2002, 23:32   #10
CriticalPoint
Multimodder
Diffuse them yourself, some sanding paper and no time at all, a nice diffused blue led. You could always just go with a couple low intensity ones, diffused, and it would look the same
__________________
Old 22nd Jun 2002, 23:48   #11
delbert
Modder
Hmmm It would only take about 10 minutes to build a blue set. I only have two (blue LEDs) here at home. I think I will order some or maybe even take a trip to Radio Shack and pick up some more. Stay tuned.
Old 23rd Jun 2002, 00:17   #12
BluFluX
Multimodder
BluFluX is on a distinguished road
I like the "hinge" lighting effect people are doing with plexi these days... very nice!
edit: forgot to mention the hdd mod... very nice indeed.
__________________
Speak softly and carry a big Dremel.
BluFluX is offline   Reply With Quote
Old 23rd Jun 2002, 00:50   #13
delbert
Modder
Ah yes the hdd mod. Just did it yesterday as it was one of those things I wanted to do before I posted. You know what the worst part of doing that mod was? Wondering if it was going to work after going to all that work. It is a 7200 rpm WD 20gig drive. Not the latest and greatest, but not something I wanted to trash. Anyhow, it has been running for like 18 hours straight so far with no problems. Full surface scan checked good.
Old 23rd Jun 2002, 03:52   #14
hydrogen18
Banned
hydrogen18's Avatar
hydrogen18 is on a distinguished road
gr8t mod though I cant stand the fact of an external PSU I would go for green leds...
hydrogen18 is offline   Reply With Quote
Old 23rd Jun 2002, 04:27   #15
Morphine
weeee!
Morphine's Avatar
Morphine is on a distinguished road
diffused high intensity blue LEDS up front and green in the back. that would be a sweet lookin transition. orrr...... make it all glow blue normall and then with HDD activity use high intensity white LEDs. then it will flash white like lightning. im doing that for my clear case. full sized case though.
__________________
Back from the dead.
Found a bigger money pit than PCs. My Tibby!
Morphine is offline   Reply With Quote
Old 23rd Jun 2002, 04:35   #16
Ubermich
He did it!
Ubermich's Avatar
Ubermich is on a distinguished road
This is definately one of the nicer cases I've seen recently. Only thing that gets me is that ribbon cable dangling helplessly out in the open, screaming, "Save me! Saaave meeeee! Any way you could get some of that temporary sticky stuff (like the stuff they seal mailed ads with), or double-sided tape, or something like that, and stick it up to the hdd bay?
Ubermich is offline   Reply With Quote
Old 23rd Jun 2002, 06:02   #17
delbert
Modder
I hear ya, and I must admit it sounds bad. When I removed the hacked up internal PSU and looked over installing the new 1U rackmount PSU I didnt want to cut it up just yet. It was close to fitting inside without being cut up but was about 1/4 inch too long.
The small brick sized power supply lives in the wall cavity behind a tackbord at my desk. When I built this office in my home I intentionall did this to hide all the cords.Notice the grey outlet in the pic with all the labels and arrows above. Then compare it with this pic and perhaps you will understand where it lives.
Old 23rd Jun 2002, 06:05   #18
ViperZ
Supermodder
ViperZ's Avatar
ViperZ is on a distinguished road
Wow Great work!
__________________
Rigs
ViperZ is offline   Reply With Quote
Old 23rd Jun 2002, 06:32   #19
DreXeL
Minimodder
DreXeL is on a distinguished road
I really like that. And I think the red looks nice as it is, a really nice contrast to the blue of the VFD.
Good work M8!!
DreXeL is offline   Reply With Quote
Old 23rd Jun 2002, 11:02   #20
Jamie
bit-tech Staff
Jamie's Avatar
I would probably have made it slightly taller (almost a cube) so that the PSU could be put in there.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
