RSS
Old 27th Aug 2002, 16:12   #1
macroman
The One
Moderator
macroman is a name known to allmacroman is a name known to allmacroman is a name known to allmacroman is a name known to allmacroman is a name known to allmacroman is a name known to all
Rainbow LED
I hope it was worth the wait
http://www.bit-tech.net/article/92
macroman is offline   Reply With Quote
Old 27th Aug 2002, 16:27   #2
MajestiX
Multimodder
MajestiX is on a distinguished road
nice work macro as always....
how bout somepics of it working or avi???
Cheers,
MajestiX.
MajestiX is offline   Reply With Quote
Old 27th Aug 2002, 16:34   #3
i_h8clowns
do you like sweeties?
i_h8clowns is on a distinguished road
w00t!
thanks macroman! : D
i_h8clowns is offline   Reply With Quote
Old 27th Aug 2002, 17:04   #4
i_h8clowns
this is the LED i am going to use. it has one less blue anode and common cathode than the LED you use. but there shouldnt be any difference right?
Old 27th Aug 2002, 17:16   #5
macroman
The One
Moderator
There are differences but it should work ok. You may need to change the resistors R1-3 to match the brightness?
Phire - why did you delete your post?
Old 27th Aug 2002, 23:02   #6
Ice-T
What's a Dremel?
Ice-T is on a distinguished road
Hello Macroman,
Is it possible to use three different LEDs instead of one RGB LED?
BTW, we really need some pics and a video!!
Keep up the good work.
Ice-T is offline   Reply With Quote
Old 27th Aug 2002, 23:04   #7
RaptorLord
Multimodder
RaptorLord's Avatar
RaptorLord is on a distinguished road
Theoretically speaking, with 1024 columns and 768 rows (if they are 3mm) that would give me a nice 3+ meter screen.... now, where to find a converter to convert a VGA signal to some sort of active matrix LED driver...
RaptorLord is offline   Reply With Quote
Old 27th Aug 2002, 23:06   #8
Cheese
Doc
Cheese's Avatar
Cheese is on a distinguished road
Very nice work Dave - time to get my iron out I think
r.
Cheese is offline   Reply With Quote
Old 27th Aug 2002, 23:09   #9
macroman
The One
Moderator
Originally posted by Ice-T
Hello Macroman,
Thanks
As stated in the article getting a good vid is damn near impossible with the kit I have. The led just whites out the picture and doesn't appear to do much!
I will keep trying and see what I can come up with.
Ice-T yes
Old 28th Aug 2002, 00:50   #10
P5ycho
What's a Dremel?
P5ycho is on a distinguished road
How about recording the reflection on an object, a wall or something?
P5ycho is offline   Reply With Quote
Old 28th Aug 2002, 14:16   #11
Yammosk
Multimodder
Yammosk's Avatar
Yammosk is on a distinguished road
if the led's are brite enough a reflection of the hand is really quite easy to get on camera!!!
Yammosk
__________________
PC Stats
2100+ Athlon XP, 1.5gig 333 DDR, MSI KT4 Ultra, 120 GIG SATA Maxtor Calypso, 40 gig Quantum 7200rpm , Gforce 4 TI 4200 128 meg , Pioneer 16x Slot DVD , 40x12x40 BTC Burner
Yammosk is offline   Reply With Quote
Old 28th Aug 2002, 14:39   #12
Fly
inter arma silent leges
Moderator
Fly's Avatar
Fly is on a distinguished road
Macro, I really want to do this but due to lack of skills I cant do the curcuit board thingy. What is the easiest way of creating one? and what do I need?
__________________
"Flying is simple; push on the stick and the houses become bigger, pull back on the stick and houses become smaller, unless you keep pulling in which case the houses will become bigger again..."
Disce quasi semper victurus; vive quasi cras moriturus.
Fly is offline   Reply With Quote
Old 28th Aug 2002, 19:04   #13
macroman
The One
Moderator
The PCB making article should be up this week. ( Maplin sell everything you need ).
Old 28th Aug 2002, 19:22   #14
Fly
Moderator
Fly's Avatar
close to home then...
__________________
Old 29th Aug 2002, 02:38   #15
bee2643
KickassAMD
bee2643's Avatar
bee2643 is on a distinguished road
nice job
any way we can see a video of it in action?
__________________
-bEE2643
]|[ E-Mail ]|[ URL ]|[ MSN:ask by emailing ]|[
bee2643 is offline   Reply With Quote
Old 29th Aug 2002, 14:33   #16
Kinsy
What's a Dremel?
Kinsy is on a distinguished road
nice work dude, however i do want to take it a bit further...
if i wanted to wire up, say, 8 more tricolour leds to the circuit, would i have to build 9 separate circuits or could i run them all off one?
also potentially, could i wire them up so at any one time, 3 are green, 3 are red, and 3 are blue, and as they change colour they shift colour along a line of them, like a chaser?
__________________
f**k me, isnt that going to take off?
Kinsy is offline   Reply With Quote
Old 29th Aug 2002, 15:18   #17
macroman
The One
Moderator
As it stands the circuit is designed to run one led only. The transistor stage could be redesigned to run more leds.
As for the chaser idea, the way to do it would be to repeat the IC2/transistor parts for each section and drive them all from the same clock (IC1).
Old 30th Aug 2002, 02:05   #18
Kinsy
What's a Dremel?
nice, but...
how dyou do that! all i can do is solder! making the hdd light kit of yours was nice and easy thanks to the diagram and a list of components...
would it be too much to ask if you could possibly draw me up a wiring diagram for 9 leds ala chaser idea with a list of components pleeeese?
be very much appreciated
__________________
Old 31st Aug 2002, 13:36   #19
brumster
Modder
brumster is on a distinguished road
Will it have instructions on how to make PCBs without using:
a) laser printer (dont have 1)
b) UV box (cant afford 1) or
c) drawing by hand (urgh)
or... how about some nice person out there actually making me one of the 10 individual LED version PCBs? Of course I'd be more than happy to pay you for your time and materials
And if that was possible (starts to push his luck) could you make me one of those rainblow effect PCBs too?
brumster is offline   Reply With Quote
Old 3rd Sep 2002, 20:25   #20
GigglesOfDoom
What's a Dremel?
GigglesOfDoom is on a distinguished road
5V?
What all would need to be changed for this to run on a 5V power source? Is it even possible with the ICs and transistors? Many of the LED headers in a PC are 5V, which is why I ask.
GigglesOfDoom is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
