#1 |
Supermodder
M³ Car PC *18.8.04 - Case Update Online!*
I have been working on this project for a couple of months now. Although I am only 16 and not allowed to drive myself yet in Germany, I decided to build a CarPC for my father (also partly because the car radio is broken). Well first of all, here are the specs:
AMD Athlon Thunderbird C 1.33GHz Asus A7M266 256MB Micron PC2100 DDR RAM 30GB 7200RPM IBM Deskstar HDD Datadisplays Vampower 7 (TFT GFX Card) 10.4" Sharp LQ10D42 TFT Display (300 nits) Netgear GA302T Gigabit Copper NIC Creative SB Live 1024 Generic USB2.0 card (VIA chipset) Leadtek GPS (Sirf 2 chipset) reciever with TMC AOpen 300W PSU Pioneer slot DVD 16x (still to be decided on) Generic IDE to USB2.0 converter Voltcraft 300W 12V Inverter As already mentioned the PC is going to be mounted in my father's car (2000 Mercedes E280 ) I'll post some pics of the car as soon as possible. Anyway, the actual PC is going to be mounted in the trunk in a custom made wooden case. Here is the progress on the case till now: This will be the final case layout: ![]() The case is made from 1cm thick wood and fits perfectly into the corner of the car's trunk. When finally mounted it will be hidden under some linnen (same as used in the trunk). Here is what I spent most of the time on till now: These are some homemade PCBs for the front controlpanel. It features touchsensor control (power, volume up/down, DVD eject) an IR reciever and a delay switch (used to fire mainboard in startup sequence). Not included yet is the safety system. Honestly I got a little paranoid about the potential hazards associated with this in car system (e.g. fire). So I hacked apart a smoke detector and connected it to a homemade circuit, which will disconnect the power to the inverter if there should be a fire. Also the alarm would sound inside the car and a master alarm LED would flash on the control panel (just to be safe ). The touchsensor control uses QT115 ICs which will fire relays (after going through a NOT gate and a darlington transistor). I hooked up DVD eject, volume up/down and power to the relays. The volume control functions through the onboard volume control of the SB Live card (3 pins which you can connect to increase/decrease volume). The power button was somewhat more difficult to design. It switches a total of 6 relays in a sequence (I'll post the schematics soon). Fortunatelly I got it all working now . Next step will be to mount that mess in a small plastic case. This again will be placed behind the dash and connected to the PC in the trunk. The touchsensors will be mounted in a CNC'd aluminium case on top of the dash (design pics shall follow when completed).This is the display I will be using: ![]() Got it for EUR 90 off eBay . Pretty good price with a bundled inverter and PCI digital interface card. It has an about 3m long cable so it even works on larger distances. The problem I first faced was DVD playback with the 1MB GFX card, which I fixed by using the VGA safe mode instead of the real drivers . Works like a dream in VGA safe mode and stutters like hell with the drivers. The panel is going to be put into a custom CNC'd aluminium case and mounted infront of the car's middle dash (able to flip down). The case will look something like this:![]() It's going to be manufactured out of black anodized aluminium ![]() Well that's enough for a first post on the project. Going to keep you updated ![]() P.S. for anyone wondering about the name of the project... it stands for Meister Mercedes Machine. It is put together out of Meister Machine (English: Master Machine) which is the common name for all the computers I make (see avatar and username) and Mercedes (obviously the car which it is going to operate in)
__________________
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius - and a lot of courage - to move in the opposite direction." - Albert Einstein M³ Car PC Main Rig: A64 Clawhammer 4000+, A8n SLI Deluxe, 6800GT, 2GB Corsair PC4000, 1.76TB total HDDs, W/C with dual radiators, Seasonic 550W 80+, Lian Li V2000+ II Last edited by Der Me!$ter; 17th Aug 2004 at 22:34. |
#2 |
Minimodder
Looks good so far...I like the shell for the TFT
But why do you use such a fast PC, only for the stuff you need in a car? Do you think the battery will be fine with a thunderbird? I'm gonna build a similar system, but i will use an EPIA and try to build it in the glovefold (?) (auch wenn ich bei uns mit 17 auch noch nicht fahren kann)
__________________
<<<|www.casemodder.de|>>> |
#3 | |
Supermodder
__________________
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius - and a lot of courage - to move in the opposite direction." - Albert Einstein M³ Car PC Main Rig: A64 Clawhammer 4000+, A8n SLI Deluxe, 6800GT, 2GB Corsair PC4000, 1.76TB total HDDs, W/C with dual radiators, Seasonic 550W 80+, Lian Li V2000+ II |
#4 |
Here comes the farmer
wow, looks like a good idea. Got to see this
__________________
\o/
#5 |
mind control
Hi there nice project you got going. 2 things I'd comment on:
1. Pioneer slot DVD 16x (still to be decided on) - my experince is these are noisy buggers. You might want to go for a normal tray loading (unless of course this interfers with PC mounting). 2. I'd suggest investing in a bluetooth dongle and then using a bluetooth enabled phone for control (acts as a remote and a mini screen). |
#6 |
Minimodder
Yeah...from what I have heard the slot load drives are loud. I don't know how noticable it will be when it's mounted, and the car is on, etc, etc. Perhaps mounting it with audio foam of some sort?
#7 |
Minimodder
Has anyone of you ever tried a normal DVD-Rom or CD-Rom in a car?
What happens when you drive over a bump or anything, will it still work properly?
__________________
#8 |
BodMod
Something labelled 'M3' in a Mercedes?!
Blasphemy ![]() Good luck with the build, dude. *n
__________________
.:inked:pierced:scarred:.
Go back to bed America, your government has figured out how it all transpired. Your government is in control again. Here, here's American Gladiators. Watch this, shut up. Go back to bed America, here's American Gladiators. Here's 56 channels of it. Watch these pituitary retards bang their skulls together and congratulate you on living in the land of freedom. Here you go America, you are free... to do as we tell you. You are free, to do as we tell you. |
#9 |
Supermodder
The reason why I am probably going to use my Pioneer slot in drive is because I had done something very stupid
. I had a slot in mini DVD drive from Panasonic, which I fried in a short circuit... chips and cables fried - nothing could be done to repair it . That drive had absolutely no problems with shocks and actually was a DVD/CDRW cobo drive. The Pioneer and other standard drives do have problems with shocks at high RPMs. The spinning CD will tilt and get scratched when the drive is jolted. I can limit the CD speed of the Pioneer down to 24x with Nero DriveSpeed which does increase shock resistance, however I am still not satisfied. There is another program called "CD Bremse" (English: "CD Break"), which can limit the drive speed down even further, however I can't get it to work with the IDE to USB adapter. I heard that Pioneer released a tool to limit the spinrate of the drive as well. Anyone seen it, got a link? And no, I can't use any tray loading drives as there is not enough space for the tray to move out where I am going to mount the drive (pics will come soon) (they are also not any more shock resistant than the slot loading drives).
__________________
#10 | |
Supermodder
__________________
#11 |
Supermodder
I always liked car pc mods so this should be fun to follow. Looking good so far! Subscribed.
__________________
~Nick PROJECT: My NEW ROOM I have 18 cool PCs...they range from Pentium 66Mhz to X2 4200+ FLICKR, eh? |
#12 |
mind control
Der Me!$ter - I take it the computer you build is going to have a free USB port? Well in that case you can buy a USB bluetooth dongle (gives your PC bluetooth cabalities) should cost too much £30odd here. And then use your phone as a remote. Software is available to do this. Plently of bit-techers have done this with their main PCs.
#13 |
Modder
this is lookin good so far im gonna keep an eye on dis mod..
__________________
Getting new PC after christmas!! Upgrade from: 750mhz duron, sis 32mb vid card (no opengl), 256mb ram Upgrade To: Amd athlon 2500+, radeon 9600xt or pro 128mb ( WOOT ), 512mb ram, Thermaltake "Romeo" case. Graaaagh! Kings of Chaos |
#14 |
Supermodder
Update:
Ok, I got the safety system circuit working now. It's nothing special, anyway here it is: ![]() Here's how it works: I hacked apart a cheap smoke detector (EUR 3.50) and tested the different ICs for usable pins. I found one, which supplies 3.3V only when a fire is detected. With this connected at the IN port of the circuit, it will fire the darlington transistor and so fire the relay. The relay will be attached to the on/off switch of the inverter and when fired will disconnect the power. The capacitor between +12V and GND is simply there to smooth out voltage swings from the battery. The smoke detector itself can run off 12V and so will be attached to the battery so that it doesn't shut itself off when shutting down the computer. Here you can see the test circuit: ![]() The PCB on the right is the smoke detector which is connected to my circuit on the right. Works like a dream .
__________________
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius - and a lot of courage - to move in the opposite direction." - Albert Einstein M³ Car PC Main Rig: A64 Clawhammer 4000+, A8n SLI Deluxe, 6800GT, 2GB Corsair PC4000, 1.76TB total HDDs, W/C with dual radiators, Seasonic 550W 80+, Lian Li V2000+ II Last edited by Der Me!$ter; 3rd Jan 2004 at 19:28. |
#15 |
Supermodder
Update time!
Ok I've spent a couple more hours on the project and here are the results: I've modded the NIC so that I can connect the LEDs to the front dash in the car. I had to dremel out the led holder as it was pretty impossible to solder it out. The NIC has 4 status LEDs: 10MBit Link, 100MBit Link, 1000MBit Link and Act, which is clearly too much information to wire in the car. So I connected diodes to the LED headers so that only one LED will light - be it 10, 100 or 1000 MBit/s. With that sorted I could insert the NIC back into the case and screw everything down. ![]() ![]() Current setup: ![]() I'll be using myHTPC as a frontend. ![]() Next I had to configure Girder for the IR remote. I Connected the reciever and it didn't work anymore ! No recieved signals, no glowing LED, nothing. Checked everything and didn't get it to work anymore. This was also when I discovered a design error in the volume control circuit which was on the same PCB as the IR reciever. I connected the indicator LEDs all to seperate resistors using seperate cables, which would be far to much cable to install from the trunk to the dash. New, stronger resistors would be required as well to supply all the LEDs at once (2 x 4 LEDs - 4 volume up, 4 down). So before soldering a bunch of wires to the PCB to correct the error I decided to make a new PCB:![]() The PCB isn't complete yet as some parts are missing so I'll have to wait till Wednesday to see if the IR reciever and the volume control are working. I test fitted all the PCBs, which are going to be located inside the dash into one case. ![]() Fits perfectly! ![]() Here btw is the remote I am going to be using for the main control of the PC: ![]() It's from a DVD player, which I control through a universal remote, so this one was available. I hand painted on the M³ text at the bottom (I have very bad painting skills, but it turned out allright ) I also finally recieved the amp which I am going to use for the audio system: ![]() Not really the best amp, but it does the job. EUR 50, new off of eBay. That's all for now, I'll keep posting!
__________________
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius - and a lot of courage - to move in the opposite direction." - Albert Einstein M³ Car PC Main Rig: A64 Clawhammer 4000+, A8n SLI Deluxe, 6800GT, 2GB Corsair PC4000, 1.76TB total HDDs, W/C with dual radiators, Seasonic 550W 80+, Lian Li V2000+ II Last edited by Der Me!$ter; 28th Jan 2004 at 18:32. |
#16 |
Relix Headshot!!
That's some bad ass **** Meister!! Hoping to have found a great project once more right here
#17 |
Supermodder
really some great work.... do you ever visit mp3car.com???
keep it up, some great stuff goin into this man |
#18 | |
Supermodder
). I prefer this forum to post my logs, etc.
__________________
#19 |
Relix Headshot!!
Dude... I started thinking... What's the car it will be fitted in?
#20 |
You talkin to me?
What about throwing a wireless network card into the system? That way you don't need to have anything hardwired to transfer files, plus you can go wardriving.
__________________
I used to be with it, but then they changed what "it" was. Now, what I'm with isn't it, and what's "it" seems weird and scary to me. |
| Thread Tools | |
| View Mode | |
