#1 |
bwarp
Moderator
Ratpads
__________________
This post is non-negotiable. All terms and conditions apply. Arguing on the internet is like competing in the special Olympics. Even if you win you're still a retard. |
#2 |
Supermodder
Hello,
I've been using one of these since September and I can't stand to use anything else. I have never used one of the Everglides but either way I love my Ratpadz. The mouse I use is the Logitech Dual Optical..very smooth and crisp! Shannon |
#3 |
\o/
I've got the 3M Precise Mousing Surface which I use with my Logitech Optical, how does the 3M pad compare with the RatPadz?
__________________
Denying Rights to Music lovers. Denying Rights to Movie lovers. |
#4 |
Supermodder
Hey,
Yeah I've used that as well...how does it compare? To put it bluntly..it doesn't. Shannon |
#5 |
Ultramodder
Can't wait for mine to "arrive"
| Phrozenpenguin |
| View Public Profile |
| Find More Posts by Phrozenpenguin |
#6 |
bwarp
Moderator
sendin 'em all during mon-fri next week mate!
__________________
#7 |
Multimodder
So peeps.......which is better???
Everglide or RatPadz? I'm about to make a purchase and want to get some input.....and since I trust you guys........whatcha think? |
#8 |
Supermodder
Hi,
Their pretty much the samething. The Everglide Giganta (spelling?) is very close to the same surface area as the Ratpadz. However, if you have an optical mouse make sure you get the black one. People have had problems with tracking on the different colored Everglides. Shannon |
#9 |
Multimodder
Thanks...I suppose i'll just flip a coin then......or I could do the right thing and get the ratpad to support bit-tech!
#10 |
What's a Dremel?
i have a everglide giganta and a logitech dual optical works for me very smooth.
#11 |
Multimodder
I heard from some people that the surface of the ratpadz lasts much longer than the everglide!
Eh Ritch, I can't believe you could bend the ratpad so that it didn't rock from side to side. I just removed the foot on the middle of the pad; that works fine for me now! (I didn't manage to bend it back properly) cu Elemental p.s.: RitchtheTitch and Titch? two different persons? Just noticed that. Always thought you are one and the same guy
#12 |
bwarp
Moderator
i've used Everglides at my dads work, and after using this I think that Ratpads are a little better. The surface is a bit more slippy, and i like the shape better - everglides require you to have your wrist in the center - ratpads dont.
__________________
#13 |
Multimodder
Thanks again.....I'll more than likely pick up a ratpad....
#14 |
The One
Moderator
#15 |
\o/
just placed my order
can't wait for it to arrive now heheordered one of those bungee things from Everglide too, I hate my mouse cord snagging!
__________________
#16 |
Pewlius Caesar
bit-tech Staff
I neeeeeeeeeeeeeeeeeeeed™ one of these!
__________________
#17 | |
Multimodder
I'll get an everglide for the game machine and a ratpad for the answering machine/mp3 player/server.....woo hoo! Problem solved!
#18 |
Hypermodder
ratpadz.com lists the following sites for USA purchases:
Outside Loop, 2CoolTek, PCMods, Arena Computers and Plycon Any of them unreliable, or preferred? Edit: Just noticed the all have the curve near the bottom... I turn mine by 90 degrees. Any alternatives w/o the curve or similar designs? Last edited by kanuslupus; 31st Mar 2002 at 21:15. |
#19 |
Multimodder
you could go for the everglide in the plain jane layout.
9 1/4 high by 8 1/2 wide....and it has no cutout...i'm not sure about the ratpad... that particular pad should be here: https://www.everglide.com/shop/produ...7&ProductID=10 |
#20 |
What's a Dremel?
Bit-tech ratpad?
as with the case badges, why not design a bit-tech rat pad, see if u can get someone to print ur logo on a rat pad
. would be cool imho:dude: :dude: :dude:
| Thread Tools | |
