Windows Trying to network 2 win7 pc's
Discussion in 'Tech Support' started by Ozzie, 15 Jul 2015.
  1. Ozzie
    Ozzie Fork 'andles I wanted
    14 Sep 2013
    Hi all, As the title I am trying to network 2 pc's. I have done this before and it should be easy but I seem to be missing something. Any help please.
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Directly connected or via a switch/router?
    What are you trying to achieve by networking them?
  3. Ozzie
    14 Sep 2013
    Thanks for the reply, I am trying to achieve printer and file sharing and also access to one of the HDD's on the secondary PC.
    The set up is this,
    PC1 connected to router/modem via wireless.
    PC2 connected to router/modem by wireless and also cable.
    Also an access point in another room wired to router.
    At the moment I can't seem to even get of the ground by setting up a network connection.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    do you have passwords on both pc's?
  5. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Should be fairly easy to setup. Are they both on the same workgroup?
  6. Ozzie
    14 Sep 2013
    I cant seem to set up a workgroup in the first place, this seems to be the problem, once I have done that I should be fine.
  7. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Create a user on each account, in my example i will use bob
    Set the password to the same
    On your file share pc setup the share (right click, properties, sharing, advanced)
    set everyone to have full control. ensure under the security that bob has full control.
    Go into network and sharing center and change advanced sharing settings, Turn on Network discovery and turn on file and print sharing.
    On your client, map it using \\<server pc name>\share name.
    This should work, any issues give me a shout :)
  8. Ozzie
    14 Sep 2013
    Thanks but I can't create an account in the first place, this is my problem.
  9. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Depending how fast the machines boot up (SSD?) it's better to map with the ip instead of sharename, windows can try to map the drives before the computer has fully booted up causing issues.
  10. Ozzie
    14 Sep 2013
    Sorry but I fail to understand that
  11. Ozzie
    14 Sep 2013
    Good morning Modd, thanks for your offer of help via teamviewer. As I have never used it before and this is a networking issue will I need it installed on both pc's or just the main one.
  12. Ozzie
    14 Sep 2013
    A bit more info. Trying to use the Microsoft "Fixit" tool tells me "The system time is different from your local standard time" It fails to fix it though.
    Looking in the bios the system time appears correct to me. The windows clock is set to sync with UTC London.
  13. Ozzie
    14 Sep 2013
    Neither are passworded.
  14. Ozzie
    14 Sep 2013
    All working perfectly now, many thanks to modd1uk for the remote assistance.
  15. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    No problem buddy you're welcome, any problems give me or one of the other guys a shout and we will get it resolved for you. :).
  16. Ozzie
    14 Sep 2013
    Just out of curiosity and no way meaning to be rude, what was your accent:)
  17. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    AWESOME. Nah it's northern, lived in Jersey though so it's all kinda fecked up.
  18. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    modd1uk: What was the problem in the end?
  19. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    There wasn't one, it just needed setting up properly :).
  20. Nealieboyee
    14 Aug 2009
    Ah I see :thumb:
