Case Mod - In Progress Bloody Angel
Discussion in 'Project Logs' started by snef, 6 Jun 2014.
  1. snef
    snef What's a Dremel?
    18 May 2014
    start another build, this one is for me, my personal Gaming Rig
    Snef's Bloody Angel
    i need a real "TOWER of POWER", at beginning, Enthoo Primo white was my first choice
    but i saw new case on Caselabs store, The SMA8
    i sent an email to Caselabs to know the shipping rate
    and i finally choose Caselabs SMA8
    generally I try to search for a unique or special color combination but not this time
    keep it simple
    Hope you will enjoy it
    Build setup/parts listing :
    Case and accessories
    • CaseLabs Magnum SMA8 White
    • CaseLabs 120.2 Flex-Bay Rad Mount
    • XXL Clear windows
    • 480 rad mount on top and bottom
    Components
    • Asus Maximus VI Formula Z87 Motherboard
    • Intel i7 4770K CPU
    • Corsair Dominator GT 16GB DDR3-2133 RAM
    • Silverstone Strider 1500w PSU
    • Galaxy GTX 780 HOF (2x) (waiting for Ti version)
    • OCZ Vertex 4 256GB SSD (2x)
    • OCZ Agility 3 240GB SSD (2x)
    • WD Green 3TB HDD (2x)
    Cooling
    • Bitfenix Spectre Pro BFF-LPRO-12025R-RP 120MM Red LED (13x)
    • Darkside 480 Radiator (2x)
    • Darkside 240 Radiator
    • Darkside D5 Vario Pump (2x)
    • EK-D5 X-TOP CSQ - WHITE Acetal (2x)
    • EK-Multioption X3 250 with white Acetal ends (2x)
    • EK-UNI Holder D5 (2x)
    • Bitspowers White Crystal Links with a lots of extenders, adapters and 90 degrees
    • EK-HD Tube 10/12mm 500mm - 2 pack (13x)
    • EK Supremacy CPU Water block - Plexi-Nickel CSQ (polish)
    • EK-RAM Dominator (CSQ) Water block - Plexi Nickel (polish)
    • EK-FB KIT ASUS M6F - Nickel
    • EK-FC780 GTX HOF - White Acetal + Nickel (2x)
    • ColdZero Custom GTX 780 HOF back plate
    • Ek Water Blocks Fluid Blood Red 1000ml (4x)
    • Aquacomputer Aquaero 5 XT USB Fan-Controller
    • Aquacomputer Flow sensor mps flow 400, G1/4 (2x)
    Sleeving, Cable and lightning
    • Darkside Red
    • Darkside White
    • Darkside Fan splitter
    • Darkside Led strips
    • Darkside 12" ( 30cm ) Dimmable Rigid LED Strip V2
    • and a lot of custom cables
    Mods
    • Painting ram
    • Painting Water block
    • Painting radiator
    • Painting Pump mount
    finally not so much mod, Caselabs generally don't need physical mod to achieve a good build
    I saw we can order parts for any case now, i can drill some hole in mid plate and back panel
    I made some test with Plasti-dip for Bloody Angel
    for sure the armor of the Maximus VI Formula will be white, but i don't want to paint it permanently, i will use plasti-dip
    sure its not the armor but give a great idea of the result and i like it , its pure white
    i tried on my Xonar Phoebus,
    Really like the result, with the custom backplate, it will be perfect
    at beginning, my plan was to add the original Asus chrome and red ROG logo sticker (you still see Asus) but they will be hidden
    same thing on Aquacomputer Poweradjust 5.25 bay, i like the results
    i did the same ting on my Aquaero 5 XT, but still in Sand of God
    now i tried to paint Angle Fittings and Crystal link C47 Fittings with regular paints
    i saw the price for 90 degree female -female angle fittings and $15 each not cheap (i know this hobby is not cheap)
    i tried to paint some
    in next pics, some are paint and some are Bitspowers,
    Not to bad, these are only test, next time, i will screw the fittings to angle before painting
    i painted black angle and crystal link with 2 layer of primer and one layer of white gloss
    What do you think?
    received some toys
    I know what I will do this week end, someone says Plasti-Dip?
    want to see the results of Rad with fan on it and I like it a lot
    like the results but its not perfect like regular paint
    but if I want to keep the shield intact to sell it later, its the only option available
    Out of town for a couple of weeks now and when I came back today, something waiting for me in front of the door
    YESSSSSS!!!!
    its Huge but I love it
    the Usual pics of the Box,
    Now, I can start the build process
    some pics of GPU tubing, this case is HUGE!!!! and use very little run of tubing
    the 6 fittings on GPU are painted one, they are exact same as original white C47
    tubing is done, i love this case, a lot of place to do any loop you want
    Usual Cpu Shoot, but i want to show the Memory block, to much nickel, add little bit of white and the result is really good
    i cheated on this one, use flex tubing on bottom, why not?
    no one will see it
    Leak test and Night shoot
    i had a leak on CPU loop (back fitting on top rad) , my fault, forgot to tight it :oops:
    i really like these night shoot, still need to see with fan led
    pretty closed to the end
    Final Pics
    some night shot
  2. Nexxo
    23 Oct 2001
    Tidy. I like.
  3. Hanoverfist
    Hanoverfist Minimodder
    11 May 2014
    Looks like Candy snef...Excellent combination of color.
    Photog skills are top notch.:thumb:
  4. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    My Mrs says it looks like an hospital but hey I love it. Cannot wait to install my Formula mobo tomorrow, they are sexy boards
  5. Nexxo
    23 Oct 2001
    No hospital I've ever worked in looks that good. :)
  6. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    this build is my favourite ever. I remember seeing it for the first time on facebook. it's got everything I like and white and red builds are awesome! especially when they're executed as well as this one
  7. photekq
    photekq Cherry addict
    11 May 2014
    Those photos are absolutely stunning. Some of the best I've ever seen. Really loving the strawberries and cream colour scheme too.
  8. snef
    18 May 2014
    Thanks guys, really appreciate
  9. snef
    18 May 2014
    Update on Bloody Angel
    now im in the X99 religion and I love it
    new Spec
    Asus X99-Deluxe
    Intel I7-5930
    Crucial DDR4-2133
    and now with 3 x GTX 780 Hall of Fame
    waiting for the third Backplate
    its a beast, im sure I can run all games @ Ultra setting, including Solitaire
    http://www.3dmark.com/fs/3303754
  10. BLAMM0
    BLAMM0 What's a Dremel?
    28 Jul 2014
    Pure modern art (y)
  11. MarkVarley
    MarkVarley Minimodder
    12 Sep 2014
    I've always loved Red on White as a design colour combination and this is just gorgeous with that.
  12. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    LOL at the Solitaire comment. :) Looking good buddy! It appears I now have a 5th forum to stalk your builds on. :D
  13. onevoicewild
    onevoicewild What's a Dremel?
    20 Dec 2014
    Mr Clean does it again! well done as usual.
  14. snef
    18 May 2014
    Thanks
  15. Thorn
    Thorn Gaijin Studios
    19 Feb 2004
    Super i love it white themes
