Guide Acrylic: Flame Polishing & Bending
Discussion in 'Modding' started by mnpctech, 27 Feb 2007.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This is a video segment from our Ghost Rider Project. It focuses on how I made the custom acrylic flames for the chassis. Helpful if you ever wondered about Flame Polishing or bending Acrylic aka "Defyant Style" :hip:
    I also open up some mod goodies and go over the current status of our prject towards the end.
  2. l0cke
    l0cke What's a Dremel?
    25 Sep 2005
    Awesome, but I LOL'd when I saw you blowing on it!
  3. Crazyglue
    Crazyglue What's a Dremel?
    27 Nov 2005
    wow, u use a blowtorch? i have never actually bent acrylic, but aren't you supposed to use a heat gun (aka hair dryer on crack)? lol
  4. shotgunefx
    shotgunefx What's a Dremel?
    4 Feb 2004
    Cool. Never did much with acrylic, but I've used a torch to shape ABS a couple times in a pinch or to prep polypropelene pieces for painting.
  5. mnpctech
    21 Apr 2003
    hehe.. I couldn't resist :hip:
  6. bobisgod
    bobisgod What's a Dremel?
    19 Apr 2010
    Can you re-upload this? It sounds really interesting and I reeeaally want to see it!!
  7. Unicorn
    25 Jul 2006
    The MNPC tech video is not available any more it seems, but this is a good demonstration of the proper technique for flame polishing cast acrylic. It works the same on thinner plexi edges:
    vmast3r likes this.
  8. NFC
    NFC What's a Dremel?
    10 Mar 2010
    This is a great tutorial. I just want to add something though:
    When you are using a torch to flame polish edges on 1/4" acrylic and lower, it is a a good idea to take two pieces of wood and clamp them flush on either side. Not only does this prevent warping, but it stops the edge from "curling" and becoming rounded. I employed this technique in my last few mods after struggling with said side effects...
    Unicorn likes this.
  9. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Any good tutorials for bending acrylic around? In particular, dealing with different thicknesses and angles. Thanks
  10. DanSonley
    DanSonley What's a Dremel?
    20 Jan 2012
    wish id seen this sooner. i ruined my as project polishing plastic wrong. everyone things my product looks fine but i know that its not got that lovely high quality finish to the plastics...
  11. Bitwacker
    Bitwacker C# forever
    9 Nov 2009
    The video is marked as private. How can we view it?
