Overclocking Intel i5-4690K on MSI Z97 GAMING 5
Discussion in 'MSI UK' started by MSIRawZ, 8 Sep 2014.
  1. MSIRawZ
    MSIRawZ MSI UK Rep
    25 Feb 2014
    I've had some question on our Facebook page recently about OC Genie and how it works.
    It's very simple and you don't need to stress test - However if you feel you have to, please go ahead. Our FAE team choose the values internally and test 100's of CPUs to determine a 'safe' value to run 24/7 that won't crash or overheat.
    Below are some OC Genie testing using the new Z97 GAMING 5 motherboard with some quick benchmark runs. I would guess most of you will buy the i5 (with the GAMING 5) so I've used the i5-4690K Devil's Canyon CPU to give you guys an idea.
    Setup:
    CPU: Intel Core i5-4690K
    Motherboard: MSI Z97 GAMING 5
    RAM: 2x Corsair 4GB DDR3-1333 (all I had lying around at the time)
    HDD: 250GB Samsung 840 EVO
    Cooler: Intel Stock CPU Cooler (yes.. stock :p)
    Power: Seasonic P-1000
    OS: Windows 7 Ultimate 64-Bit
    The CPU default frequency is 3.50GHz and the memory default frequency is 1333MHz.
    In OC Genie mode, the CPU and memory frequencies can be overclocked to 4.00GHz and 1600MHz.
    Default Settings: 3.50GHz
    OC Genie Mode: 4.00GHz
    CPU Mark
    Default settings score: 656.
    OC Genie mode score: 693. CPU frequency: 4.00GHz.
    CINEBENCH 11.5
    CPU default settings score: 6.28. OpenCL score: 31.78.
    In OC Genie mode, CPU score: 6.74. OpenCL score: 33.38.
    Super PI (32M) - 24 Loops
    Default setting: 8m45s; Temps: 37~45 degree.
    OC Genie mode: 8m3s; Temps: 53~65 degree.
    CPU’s ALU and FPU in CrystalMark 2004
    Default settings: CPU’s ALU score: 89,412; FPU: 72,864.
    OC Genie mode: CPU’s ALU score: 95,475; FPU: 78,149.
    AIDA 64 Cache & Memory
    Default settings: Memory frequency: 1333MHz
    OC Genie mode: Memory frequency: 1600MHz
    PCMark 8 - Creative Accelerate Mode
    Default settings: 2,954.
    OC Genie mode: 3,270.
    MSI OC Genie provides a simple way to overclock the CPU, and a good 'free' performance boost with very little effort required.
