News Aqua Computer launches KryoM.2 SSD coolers
Discussion in 'Article Discussion' started by Gareth Halfacree, 24 May 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    That's the second article that this has crept into. Are Geil now sponsoring bit-tech? ;)
    Is throttling really an issue with M2 SSDs? Would a normal, Northbridge style heatsink in the normal M2 position work just as well? Or is it that the M2 connector is often situated quite close to the CPU socket?
  3. Gareth Halfacree
    4 Dec 2007
    No. Something is poorly in the CMS.
    How bizarre.
    EDIT: Looks like saving the article again (after making precisely zero changes) has 'fixed' the problem. Still needs looking into, though.
  4. Gareth Halfacree
    4 Dec 2007
    It's *everywhere* - even in Antony's MOTM post on the main page. I've created a feedback thread and alerted t'editor.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    The problems with throttling has been exaggerated in reviews, the problem is that benchmarks put SSDs under an unrealistic sustained load, while in real life any serious load on the SSD will be over in less than 5 seconds allowing it to cool down naturally.
    Worse, its usually under the GPU and would conflict with its cooler.
  6. rollo
    rollo Modder
    16 May 2008
    Pretty much, reviews put most ssds through max throughput tests for hours in benches. My own m2 ssd is not even warm to touch and that's with two gpus under water, with little to no air flow ( system has been on for about a week.)
    I would also question who in there right mind would buy something like this.
    It's like fans on system memory. If your overclocking the nuts of your memory and have no air flow maybe needed. Reality is nobody does though.
  7. Flibblebot
    19 Apr 2005
    They do seem to put the M2 socket in the worst of places - the most common place is next to the CPU socket or next to the PCIe slot, I'm sure I even saw one motherboard where it was in between RAM slots. All three places limit the cooling potential - but I'm not convinced it's really a problem. As you say, those kinds of sustained loads aren't going to happen that often in general use (assuming the M2 is used for the OS).
    Still, I find myself wondering what Geil think about the matter? ;)
  8. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Immerse everything in mineral oil!
