Hi all, Due to work & real life, I have not been able to keep up with the movement in monitor developments over the last couple of years. I need a monitor for my son, usage will be homework, web browsing and gaming (hopefully in that order) and I would *like* the following features: 1920x1080 resolution IPS panel if possible Thin bezel Looks good Height adjustable if possible USB 3.0 ports if possible My budget is £150 max. If I had a higher budget I would probably just get him a Dell U2414H... So bit-tech, what is the next best thing to a Dell U2414H for my budget?
I was looking at that, thanks for the feedback. In my searches I found a Dell P2417H on NRGIT for £159 which is cheaper than Scan and is still a new unit with 3 year warranty. I assume the P2417H is just a larger version of the P2214H? I like the idea of the larger screen real estate.
I was literally just about to post about NRG:IT. https://www.nrgit.biz/pages/search-...ge=1&rb_price=75,150&rb_stock_status=In+stock Try that
Thanks guys, after checking NRG's site and reading some reviews on TFTCentral, I think I am going to go for the P2417H for £159 from NRG unless anyone can tell me about a better deal?
Cheers mate, I've pulled the trigger on the P2417H from NRG, my boy will appreciate the larger screen real estate. Thanks all for your help, rep all round.
