Web Getting into website design
Discussion in 'Photography, Art & Design' started by CCA, 23 Jul 2012.
  1. CCA
    CCA What's a Dremel?
    27 Dec 2010
    Heya'll,
    I could use some advice. I'm wanting to go into website design, primarily to create my own website at first for portifolio purposes.
    Where should I start? I've already got a general idea in my head of how the website should look, but I know nothing about how to go about creating it. Pointers to tutorials/guides for newbs etc. would be much appreciated.
    Regards,
    CCA
  2. longweight
    7 May 2011
    I've just started using wordpress.org which puts a nice front end on HTML and is making it quite easy to learn.
  3. Pieface
    Pieface Modder
    8 Mar 2009
    longweight likes this.
  4. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Agreed with Pieface. W3schools is a great learning resource.
  5. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    W3Schools is all code and while this is probably the most important thing, you'd maybe want to look into Dreamweaver tutorials as well -- thought IMHO you're best going split pane and editing the code from the in built text editor, and using the other pane for site preview.
  6. CCA
    27 Dec 2010
    Many thanks to you all for the advice ^_^. I'll investigate the w3 site. Unfortunately, I don't have a copy of Dreamweaver anyway, and have yet to acquire one.
    CCA
  7. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Web design goes beyond images and making things look pretty.
    Broadly, a good designer will have an appreciation of:
    • HTML/CSS/JS
    • Form design
    • Interaction design
    • Usability
    • Design skills
    • Platform tailored design
    • The use of fonts, font styling etc
    • Much more that i cant think of!
    But yes, a good start is W3C to get the basics on HTML/CSS :)
  8. CCA
    27 Dec 2010
    Small update: got a copy of Dreamweaver \o/.
    Thanks for the list aLtikal, very useful to keep in mind :).
    Time to start playing around in earnest x).
  9. NewERA
    NewERA What's a Dremel?
    10 Mar 2012
    I'm a webdesigner, and i strongly recommand you to make a wordpress blog. NO, wordpress blog does not have to look like a BLOG, they can be ordinary websites ! take a look at www.templatemonster.com and see some wordpress templates for yourself.
    Trust me, you don't want to build a website for yourself from zero, it's like you learn jewlery to make your diamond wedding ring.
  10. jrs77
    jrs77 Modder
    17 Feb 2006
    As I'm a webdesigner too I would recommend starting with something easy like simple HTML+CSS sites instead of using content management systems like wordpress, which are based on PhP and SQL.
