Watercooling Quad Loop Water cooing
Discussion in 'Hardware' started by BigBig5, 12 Sep 2011.
  1. BigBig5
    BigBig5 Single Braid Sleeving
    28 Apr 2010
    I want to make a Quad Loop Water cooing setup. How would I start this? I only found info on dual loop.
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I did quad loop once.
    Never again. I would suggest re-examining why you want to do so. If it's just for looks, dump the idea. If it's for performance, one loop can often outperform two.
  4. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    I have quad loop,(and room for more if i require)
    Why, Coz i can.
    How?. well i used 4 pumps and split bay resevoirs are useful, if you wanna save bays, if case too small.
    I assume you want to do ram, cpu,gpu,nb?.
    Having separate loops makes it so easy for maintenance, not having to drain cpu loop, if you just wanna clean out gpu, etc.
    Id start with a big case though if possible, to fit it all inside.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Well RAM is pointless, as it produces no heat these days. Motherboard and CPU could easily be tied in together with no performance loss. So that just leaves a sepperate GPU loop, but is it really worth the cost of a sepperate pump, res, rad just for a tiny amount of performance gain? For my I'd prefer to spend the money on SSD's...
    With multi loops there's very few pro's and many con's...
  6. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    I completely agree with Bloody_Pete. I run cpu(2600K)//gpu(2x560Ti) and when folding the water only hits 37C. My rad is a 2x140 in the top of the HAF-X. 2 loops at most will probably work for you.
  7. bulldogjeff
    2 Mar 2010
    you have to do it, I'm running triple...Loads of loops are fun.:clap::clap:
    And in the not so distant future I will be doing some thing with 4 loops....But now I'm revealing to much...lol
  8. KayinBlack
    2 Jul 2004
    Loads of loops are loads of problems.
    Besides, temps actually can suffer doing single loops for everything. Due to the thermal capacity of water, it's better to aggregate your radiators and use redundant pumps for safety.
  9. Bloody_Pete
    11 Aug 2008
    You are, however, quite mad... :p
  10. Guest-44432
    Guest-44432 Guest
    I came from a single loop with a 360 and 240 rad on my tri SLI setup and CPU. Basically I was boiling the water.
    I then went to a triple loop setup. 360 rad for the GPU. 240 for the CPU, and 240 for the mobo chipset.
    I now at present have 2 loops. Gpu's and CPU with a 1080 rad, and 240 rad for the mobo chipset.
    This works very well and keeps everything very cool due to the amount of water in the loop. With the overclocks in my sig, CPU temps maxes out at 60c. Gpu's max out at 48c after 4hrs of solid gaming.
  11. KayinBlack
    2 Jul 2004
    That was a nightmare. No matter how cool it looks.
  12. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    needs more tubes.
  13. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    u should have each component having its own loop.... including hard drives and everything!! then you have my respect :)
  14. Roskoken
    Roskoken What's a Dremel?
    15 Jul 2011
    That just kinda looks like a Japanese tentacle monster is trying to have sex with your motherboard. If thats the look you wanted, congrats!
    Fuganater likes this.
  15. Fuganater
    6 Jul 2011
    +rep for the chuckle
  16. kenco_uk
    28 Nov 2003
    You're going to need a bigger loft.
  17. Unicorn
    25 Jul 2006
    This. This is the only thing that you need to take from this thread. It's not a bad idea, but it's not really a good idea either. Triple loop setups are difficult enough for me, and I've been "plumbing" for a long time. If you think you can pull off a quad loop setup, good for you. My advice is still for you not to try it though.
    Like KayinBlack, I've only ever done it once, and will never do it again. No amount of hardware needs four loops and they are far too difficult to install neatly unless your case is 100% custom fabricated to accept four radiators, four pumps, four reservoirs and enough tubing to plumb a bathroom with. It's just not worth the hassle and added expense. Not even a little. Not even for bragging rights.
  18. PabloFunky
    19 Sep 2010
    I certainly wouldnt of attempted a quad loop if i had a smaller case, thats for sure, but i designed my build around watercooling to start.
    Ive never had any issues with any of my watercooled builds, not sure what all the problems are?.
    Only issue i did have (but was on a setup/test stage, was Shitspower 45s leaking on me.
    Watercooling ram is prob pointless on newer builds, my ram only gets mildly warm.
    But it seriously makes it easy for maintenance with separate loops.
    I think once you know loop combinations of components that are reliable, then stick with that.
    I just hope i dont get a leak, with all this liquid, because im not that good at swimming.
    Money wise wasnt an issue for me, but if your worried about cost, then stick with dual.
  19. Fuganater
    6 Jul 2011
    What case can even handle 4 loops? The only one I can think of is the Xigmatek Elysim
  20. PabloFunky
    19 Sep 2010
    Not sure what off the shelf can handle 4 loops, but i assume people on here will let you know.
    I dont buy off the shelf cases personally, and my case is massive,
