Case Mod - In Progress TJ11B-WMod - UPD 30/05/2022
Discussion in 'Project Logs' started by Scare, 3 Aug 2014.
  1. Scare
    Scare What's a Dremel?
    5 Jan 2014
    Hi All! :rock:
    Now im modding my TJ11B-W, prepare it for watercooling stuff and better cable management.
    Hardware was:
    CPU: i5 3570k
    MB: Asus z77 Sabertooth
    RAM: Corsair Vengeance 1600C9 LP 4x4Gb
    GPU: NOw i have only 660GTX 2Gb and i really want to change it.
    SSD: Kingston V200+ 60Gb
    HDD: WD Caviar Blue 1Tb x2
    PSU: OCZ Modxstream 700w
    CF: Scythe Glide Stream PWM 1300rpm
  2. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I am ALWAYS ready for a TJ11 mod.
    Good luck!
  3. Scare
    5 Jan 2014
  4. Scare
    5 Jan 2014
    UPD 08/08/2014
  5. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    Hmm... interested in the button splitter! What will they be doing?
    Looking good so far, excited to see more!
    -Jeffinslaw
  6. hero1
    hero1 Minimodder
    18 Oct 2013
    This looks good. Subbed:thumb:
  7. Scare
    5 Jan 2014
    something was here
  8. Scare
    5 Jan 2014
    Okay, a little brake over xD
    Will do a new one, for 16mm buttons and MORE black
    O-Ring testing
    And sleeving...
    Also got this baby:
    And decided to go with single rad. So 560 rad holder will be done soon.
  9. Scare
    5 Jan 2014
    Rad holder and control panel are done.
    I don't have photo of rad holder, nothing special there.
    Also add bottom lightning (able to switch on/off in final build)
  10. Thorn
    Thorn Gaijin Studios
    19 Feb 2004
    good jobs
  11. Scare
    5 Jan 2014
    Well it's still alive, still unfinished and it's totally reworked now.
    It has a new 560rad+D5 pump+aquaero 5lt mount system on rigid tube:
    Some plastic decorative parts on front panel:
    And modified monoblock, clean and shiny:
    Also since year 2015 some parts was added:
    Second D5 Pump
    360x60 Radiator
    Double reservoir
    Custom cables
    Custom case parts
    Now i'm waiting for some parts to finist some steps.
    Now it's looks like:
    Monkey Puzzle and Cheapskate like this.
  12. Cheapskate
    13 May 2007
    Was this another case of, "got it running, stopped modding it" ?
  13. Scare
    5 Jan 2014
    Sometimes we need to wait M2 SSD with no wires to make a clean build.
    Upper bay tubes in progress
    Now tubes go lower and i can install really long VGA, maybe up to 34cm.
    Next step - a custom bracket for 360mm radiator, not for 240mm like now from previous version of this build.
    D5 pump will go lower and i will try to replace res tube for 200mm or something.
    And replace all fans xD
    Because even both of new CM 360 masterfan has damaged/noisy bearing.
    Bottom 140 fans are just old, they was installed 5 years ago and i will replace it for Arctic P14.
    Custom case parts allows me to do it really easy.
    Because i have access to all fan screws
  14. kim
    kim hardware addict
    10 Jan 2016
    :thumb: beautiful, very elegant loops :rock:
  15. Scare
    5 Jan 2014
    Fillport slider system:
    And 2mm steel 360mm custom grill:
  16. Scare
    5 Jan 2014
    Got some another TJ11 parts, so new side panel
    Work in progress, but this how idea looks like.
    Side panel will be restored to normal state (solid black).
    Also custom metal frame will be polished and tempered glass inserted.
    Some hardware also incoming.
    Cheapskate likes this.
  17. Scare
    5 Jan 2014
    Little update and little upgrade
    MB now is x470 Crosshair VII + 5800x CPU (was x370 Crosshair VI + 3700Pro)
    and new GPU (6900XT Speedster Zero)
  18. Scare
    5 Jan 2014
    A little changes
