Memory What mhz is your ram...?(poll)
Discussion in 'Hardware' started by penryn 2 hertz, 15 Jun 2015.
What mhz is your memory#?
Poll closed 23 Sep 2015.
  1. 1333mhz
    6.0%
  2. 1600mhz
    53.7%
  3. 1866mhz
    11.9%
  4. 2133mhz
    9.0%
  5. 2400mhz
    17.9%
  6. 2666mhz
    1.5%
  1. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    What frequency is your rams?
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    2400MHz rated but running at 1866MHz.
  3. Mister_Tad
    27 Dec 2002
    1600MHz running at 1600MHz
    Is there a discussion or question at the root of this, or are you just looking for a sound-off? :confused:
  4. RedFlames
    23 Apr 2009
    2133 as it was cheaper than the 1600 stuff when I bought it
  5. penryn 2 hertz
    10 Jun 2010
    Just some little research before i make a purchase...:clap:
  6. Big Elf
    23 Apr 2009
    2000MHz running at 2000MHz
  7. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    TBH there's probably not much of a difference you'll see in the real world?
    I don't notice it, I'd say save your pennies and go for something that meets your budget/is optimal for the chipset you're using.
  8. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    16GB 1333, 8GB 1600 (2x8gb is expensive :( )
  9. TheMadDutchDude
    23 Aug 2013
    2400MHz running at 2600MHz because my board plain refuses to boot with XMP at 2400. :D
    2200 and 2600 run fine, but 2400 it cannot POST. Go figure... LOL.
    I think it's a RAM strap issue on the Maximus VII Impact. Well, it is on mine at least.
  10. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Isn't knowing the Mhz pretty pointless unless you know what timings it's running at?
  11. Deders
    Deders Modder
    14 Nov 2010
    2333, but running at 1800@ cas 8. Really not sure which option to select.
  12. Teelzebub
    27 Nov 2009
    1866 @1866
  13. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Main pc is running 2400mhz @ 2400mhz since it was only £10 more expensive than 1600mhz, media/lan pc is running either 1600mhz or 2400mhz cannot remember and my dads pc is running 1600mhz.
  14. TheMadDutchDude
    23 Aug 2013
    There's also that, and there's also the varying fact of which chip is on the module. Is it Samsung, Hynix CFR/MFR or something else? It's very likely to be either CFR or MFR these days, as they're cheap to produce. There aren't many good Samsung modules out there anymore.
  15. asura
    asura jack of all trades
    22 Apr 2009
    800Mhz... :worried:
  16. Mister_Tad
    27 Dec 2002
    More info to feed the research...
    Desktop - 1600MHz @ 1600MHz
    Server - 1600MHz @ 1600MHz
    Play laptop - 1600MHz @ 1600MHz
    Work laptop - 1600MHz @ 1600MHz
    Wife's laptop - 1600MHz @ 1600MHz
    My phone - 1600MHz @ 1600MHz
    Wife's phone - 1600MHz @ 1600MHz
    1600MHz seems pretty popular in this household, 72GB of the stuff in total. I have another phone too but the internet isn't forthcoming with the memory speed, I'm going to say it's 1600MHz @ 1600MHz though.
  17. Deders
    Deders Modder
    14 Nov 2010
  18. wolfticket
    19 Apr 2008
    1866mhz, probably running at 1600 I think. I only bought the slightly faster stuff because I was using an APU for a time and that is as far as I know one of the few scenarios where you actually see substantial benefits from faster ram.
    It's seemed to default to 1600 unless manually changed though, and I suspect I didn't bother changing it last time I refreshed.
    Also, I went from dual channel 8GB to single channel 4GB. Didn't really notice any difference. I feel like ram is one of those things that (as long as you have enough) the return on additional investment is fairly small.
  19. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    2400 @ 2400 10-12-12-31
  20. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Mister_Tad I think you need a new custom user title: 1600MHz @ 1600MHz LOL
    I have two 6GB kits, one rated 1866 and the other 2000, and they are running around 1400 because of my OC. I had planned to do some tests to see what difference memory speed/latency makes...maybe I'll do that later today. My understanding is that anything north of 1600MHz doesn't make a lot of difference, and it does depend on the architecture of the system - eg quad channel 1600mhz should outperform pretty much anything else.
