Blogs Windows 7 gave my PC insomnia
Discussion in 'Article Discussion' started by Sifter3000, 25 Jun 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. capnPedro
    11 Apr 2007
    This happened to me when I first installed Vista.
  3. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Hmmm. With XP, I had a similar problem - If I hibernated the PC, I would be awoken at 7.12 am every day. Doing a full shutdown prevented this. I did a new install of XP and it changed time to 02.18am instead, which makes me think it's not a Wake-on-LAN thing.
    Now I'm on Windows7, I shall see if your tip helps. Thanks.
  4. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    Haha, I experienced this too. Only when I tried accessing my laptop from my Xbox 360. Then I thought, wait, I probably need to wake my laptop off. Then the lights came on and it turned itself on. lmao
  5. coolius
    coolius What's a Dremel?
    29 Jul 2007
    This has happened to me with both 7RC and Vista, very annoying to get woken up by piercing blue leds!
  6. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    That's nothing. My computer was fully Shut Down, and managed to turn itself on at about half 3 the other morning.
    I mumbled something along the lines of "What the ****" in my semi-conscious state, turned it off again, and went to bed. Nothing since. Very odd.
    And since there is no OS running that can turn the PC on, I am still to this day confused as hell.
  7. capnPedro
    11 Apr 2007
    Was it Media Center Edition? MCE wakes the PC at the same time every day to update the EPG, then doesn't bother putting it back into standby, but there's a tool to change the time (no way to change it through Windows natively however!)
  8. GoodBytes
    20 Jan 2007
    It is a driver issue.
    I recall the same by many people who tried Vista beta.. but was fixed once Vista was out and official drivers (and sometimes BIOS update) was released.
    I expect the same as under Win7.
    You can see the Event log of WIn7 to see what makes it wake up, it could be a device that does this.
    I have Win7 RC 64-bit on my laptop (dual boot with Vista), it's the Latitude E6400 with the Nvidia Quadro NVS 160M. And despite having Vista 64-bit drivers, and Win7 beta drivers for the video card, it doesn't have any sleep problem.
  9. dicobalt
    dicobalt What's a Dremel?
    21 Mar 2009
    Low power modes have never ever worked correctly for me on any computer I have ever had with XP/Vista/7. I don't bother with it anymore.
  10. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    My old computer had a bad power supply, I'd try and turn it on then wait....and wait....and wait....untill about 10 hours afterwards at 5am it would decide to turn on XD gotta love dodgy power supplies :)
  11. GoodBytes
    20 Jan 2007
    That is because you do something that you should not do... probably attaching a bad device, or enabled USB wake-up, or play with the BIOS sleep option.
  12. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    do you have an optical mouse? that was my brother issues his mouse was sensitive to movement that the slightest vibration could set it off. Personally I have had no issues with sleep but Im running on my EeePC 1000he.
  13. Paradigm Shifter
    10 May 2006
    An issue I have encountered also. However, I didn't do any searching for an answer as I'd discovered (by accident rather than design) that if I had the system disconnected from my home network, it didn't wake up from Sleep unless I told it to. As soon as it was talking to the network, it would wake itself up after a few minutes of being asleep. I assumed this was Wake On LAN, so disabled any wakeup related features of the network cards.
    dicobalt has a point, Goodbytes - pretty much every system I've overclocked has had issues with low-power states once taken more than about 5% out of spec. In XP it usually resulted in Standby refusing to come back, or just plain resetting the system rather than going into Standby... in Vista/Win7 it either refuses to wake up, or goes into Sleep then immediately goes back to the Windows login prompt.
  14. docodine
    docodine killed a guy once
    10 Feb 2007
    The only device that sleep worked perfectly for me is also my EeePC, though I have the 4G.
  15. GoodBytes
    20 Jan 2007
    I have 10-11 systems that I build with 2000, XP, Vista, Win7 in the course of my life (considered as official builds). Excluding any beta version and considerate latest BIOS and drivers, all my system overclocked or not, sleep and hibernates all correctly. Even back in days where I was too young to build computers and did not even have the internet, Win95 and 98 worked correctly for us, I and my older brothers and parents don't recall such issue.
    My experience was always assemble the system, install Windows then driver and system is up and running correctly. After OC, it still works correctly.
    If OEM's can do it, so can you.
  16. knuck
    knuck Hate your face
    25 Jan 2002
    slightly off topic but i installed 7 on my laptop with a brand new 320Gb 7200rpm hitachi drive and it runs amazingly smooth ! I am really impressed so far by both my laptop and 7's lightness. I knew it ran perfectly on my pc but that wasn't a surprise. My 3 year old laptop however is impressing me
    Dell XPS M1210 - Core Duo 2Ghz - 2.5GbDDR667 - GeFoce Go7400 - 320Gb 7200rpm
  17. UnFixed
    UnFixed Unknown
    29 Dec 2008
    I had a printer a few years back that went bad. It started turning on randomly and would attempt to filter through the sheets and print random lettering. And this was UNPLUGGED from any computer and/or network.
    Those old printers were old, and mine scared the **** outta me.
  18. UnFixed
    UnFixed Unknown
    29 Dec 2008
    Those old printer were loud*
    *typo*
  19. Horizon
    Horizon Dremel Worthy
    30 May 2008
    thanks for the fix, i had resorted to scheduled shutdowns. it was really annoying sometimes for example, when i'd put the computer to sleep and it would resume almost immediately.
  20. Tris
    Tris What's a Dremel?
    17 Jan 2003
    had the same problem when i installed windows 7 on my htpc, was a fairly easy problem to figure out with the aid of google tho.
    The thing I am currently banging my head against is when i hibernate the machine (via remote control), when i wake it from hibernate (still via remote control) it powers up, then goes off again. Always wakes and starts working the second time i wake it. Very odd.
Tags: Add Tags
