Windows Word freezes when I go Files>Print
Discussion in 'Software' started by nichos, 15 Jan 2015.
  1. nichos
    nichos Minimodder
    17 Feb 2006
    Hi,
    Have used word 2000 daily at home ever since it came out & the last 2-3 days it freezes when I go Files>Print & so am unable to alter things in printing all other functions in File work OK.
    I can print OK via the print icon.
    Uninstalled MS Office & reinstalled it with no effect. ...thanx ...nick
    PS. Also 1. when I open word it tries to configure itself then says Error it is not functioning use Repair and it opens & works OK except for the "File>Print issue mentioned above"
    2. Deleted the two small programs recently installed
    3. recently installed my old Epson c48 & when it did not work I deleted it.
    Home build, Asus P5K Premium WiFiiFi Intel,
    Intel Core 2 Quad Pro Q6600 95W 2.4GHz, OCZ Vendetta Cpu Cooler,
    2x2GB, 240-pin DIMM, DDR2 800 (400mhz) PC2-6400,
    EVGA GeForce 9800 GTX KO 512MB GDDR3 (PCI-E),
    Seagate Barraguda sata 500gb, TOSHIBA vb63700-A 500GB external HD,
    Corsair TX750M Psu, X45, XPhome/Win8
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    What is your default printer set as?
  3. nichos
    nichos Minimodder
    17 Feb 2006
    To the only one I have HP Deskjet 1510 series
  4. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Sounds a bit like lag from trying to communicate with a network printer?
  5. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    I have a network printer and I never encountered this problem. My printer is also a HP but it's an officejet 4500 series..
  6. nichos
    nichos Minimodder
    17 Feb 2006
    Is not a network printer, is via a USB connection to my PC
  7. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    I would try a full driver removal using print management (MMC), then re-install the printer, this normally clears this issue.
  8. nichos
    nichos Minimodder
    17 Feb 2006
    I installed a new driver.
    How do I remove it with MMC?
    I have no cd forn the printer, it installed itself when I connected the USB cable.
