Other Just had a big brownout. Should I... do anything?
Discussion in 'Hardware' started by oscy, 7 Sep 2014.
  1. oscy
    oscy Modder
    22 Sep 2011
    The lights didn't just dim, they went out for a split second. That's a brownout, right? Also my computer made a sorta noise for an even shorter split second, not sure how to describe it. Anyway, my computer is still going, I've exited the game I was playing and had coincidentally saved right before this happened.
    Is there any precaution I should take, or something that might happen in the next few days, like it dying on startup or some slow horrible death? Not a UPS, I'm talking in direct relation to this brownout rather than future preventive measures. Like holding the computer's power button when it's off to get rid of the excess charge or something.
    And if anyone says something along the lines of "brownout in your pants", you're getting a backhand.
  2. Teelzebub
    27 Nov 2009
    Did it leave skid marks.
    Sorry can't resist a challenge lol
  3. Nexxo
    23 Oct 2001
    ^^^ We all went there... admit it. :p
  4. theshadow2001
    3 May 2012
    My instinct on this is that if something is running with less power than normal, then it shouldn't do anything too bad especially if its only momentary.
  5. Shirty
    18 Apr 1982
    I too arrived too late to make exactly the same comment as Tel.
  6. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    By UK standards I live in an area with frequent power cuts and they haven't damaged my computer.
    So don't panic! :thumb:
  7. oscy
    oscy Modder
    22 Sep 2011
    I live in the UK too, blackouts are rare here but I've had a few, but what about this type of brownout? I've had the lights dim for a split second, but not go so low that they turn off completely for a split second, and yet the computer keeps running like nothing went wrong (except for that noise, which I guess I'd describe as like a crumple).
  8. Teelzebub
    27 Nov 2009
    Where I live power cuts are frequent had as many as 5 in a day damned annoying having to go round the house rebooting 3 rigs every time.
    we get those quick low power ones a lot, never once has it damaged the rigs.
  9. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Modern PSUs should deal with most things without a hitch even continuing to supply power after power has cut out (momentarily anyway). I wouldn't worry.
  10. oscy
    oscy Modder
    22 Sep 2011
    Just thought I'd confirm that my computer is still alive and I've had no problems.
    Now watch as I get a BSOD.
  11. The_Crapman
    5 Dec 2011
    That noise you heard was the little known 'power straw' feature that most PSU's now have. In the event of a temporary power drop or outage, the PSU will actually suck all the electricity from the ring main it's on. The noise is when it's almost run out of electricity and has to work really hard to suck through those last few drips, much like when you've got down to the dregs of your favourite carbonated sugar beverage.
  12. oscy
    oscy Modder
    22 Sep 2011
    I'm not sure whether to believe this because I don't know any better or challenge you because that sounds crazy.
  13. Bede
    Bede Minimodder
    30 Sep 2007
    Lightbulbs emit light as a symptom of electrical current running through them. Less current, less light. Computer more complicated.
    Honestly unless you're willing to go through capacitor by capacitor, trace by trace, the only way you'll know if something is wrong is when it breaks.
  14. Isitari
    Isitari Minimodder
    6 May 2009
    Brownouts are normally used when it becomes impossible to keep the voltage in between the desired thresholds. By reducing the voltage they can regain stability and hopefully prevent a full blackout. Some items will pull a lot more current to make up for the lack of voltage (power = current x voltage). Other items won't. You can find more info as ever on Wikipedia http://en.m.wikipedia.org/wiki/Brownout_(electricity) \o/
  15. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Brownouts shouldn't damage your computer, because like Isitari said, a brownout is a drop in voltage, The worst that could happen is your computer losing power without shutting down.
    What will damage your computer is voltage spikes - brief moments when the voltage is too high, usually during storms. That could fry your computer unless it's protected.
  16. oscy
    oscy Modder
    22 Sep 2011
    I had a big ol' thread about this a while ago, and the conclusion that thread came to was that having a surge protector is probably useless, maybe even more of a risk, and any of the cheapish ones you can get in a regular shop doesn't have enough protection. But it was all hotly debated and unclear.
    Indeed, when I had a surge protector, my PSU got busted anyway. My protector buzzed for a sec then my computer suddenly turned off, and I had to get a new PSU to get it working again.
    P.S. I'm guessing the first line should say 'brownouts shouldn't damage'.
  17. Flibblebot
    19 Apr 2005
    Most consumer surge protectors aren't worth the money you pay for them, and most "guarantees" will never pay out the money they promise.
