News AMD's AM4 socket captured on camera
Discussion in 'Article Discussion' started by Gareth Halfacree, 19 Sep 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Personally I prefer LGA, while it is easier to damage the socket while putting the chip in or taking out. Once the chip is removed it is extremely durable and can be left to rummage around a box for months no problem. PGA are easy to remove but extremely delicate once they are out and the pins very easy to bend.
  3. Impatience
    Impatience Minimodder
    6 Apr 2014
    It just looks.. Cheap. Having a plastic socket compared to the Intel's metal one. Even a metal cover for the raised back portion would've made it look more durable and premium.
  4. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    I do prefer the LGA socket style as well, zero chance of having the CPU get stuck to the cooler when removing it.
  5. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    Totally the opposite for me. PGA is so much better, because if you bend a few pins, all you need is a mechanical pencil to fix it. If you bend the pins on a motherboard, you're screwed.
    If you intend to use a CPU again after taking it out, you should never let it "rummage around a box for months" even if it's LGA. Why do you think they're shipped with so much protection? Even when you buy CPUs in bulk without heatsinks, they come with static-proof foam padding and a sturdy box.
    Regardless of what you get, the protective containers that CPUs come in are small enough that they're worth keeping. Personally, I tend to only keep the AMD containers, since they're big enough to fit just about any CPU and they come with the foam padding if I happen to need that.
    Also, I'm surprised people are still complaining about things like a plastic socket. The heatsink will cover it up completely and it's a proven working method - why do you care what it looks like?
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    It's six and half a dozen for me between LGA and PGA, personally. Working with either needs a bit of care. Completely agree about not leaving bare CPUs rattling about in a box, though!
    I also agree with jrs when it comes to frequent CPU swaps - by the time I come to upgrade a CPU these days, I'm going to be buying a new motherboard (and probably memory too). My days of buying a cheap CPU as a starter and then moving up to a higher-end chip on the same socket are done, I think.
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I'm the same - I probably go years in between CPU upgrades these days.
    I think they could have pushed the boat out and found space for another 6 pins, though...;) :D
  8. mi1ez
    mi1ez Modder
    11 Jun 2009
    Last CPU I bought was LGA775!
    Damn, I need to build a PC!
  9. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Agreed!
    Those six extra pins wouldn't even have to do anything - they just needed to be there. What a missed opportunity!
  10. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Form a warranty point of view I totally get PGA.
    ~AMD~
    User - My system wont POST
    AMD - Are the pins on the CPU bent?
    User - Yes
    AMD - You gone ****ed it then, buy a new CPU....
    ~Intel~
    Intel - *Sigh* Ok send it back for RMA
    User - Inserts new CPU into ****ed LGA Socket 'Hey Intel this one is broken too...'
    Intel - *Sigh* is your board broken?
    User - No its brand new (But I installed the CPU upside down with a hammer)
    People are stupid.
  11. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Isn't PGA/LGA a cost thing, LGA being cheaper/easier to convert for use as BGA.
  12. Harlequin
    Harlequin Modder
    4 Jun 2004
    doesn't intel want to go BGA soon anyway?
  13. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Gimme a Slot 1 anyday.....
  14. schmidtbag
    30 Jul 2010
    As far as I'm aware, LGA is cheaper for the CPU, more expensive for the motherboard. I personally don't find either one easier or harder to use.
    BGA is cheaper than both...
  15. Gareth Halfacree
    4 Dec 2007
    YES!
    Fun fact: I used to have a Pentium III Slot 1 server which would only boot from cold if you hot-plugged the CPU. No, really. Hit the power button with the CPU seated safely in the motherboard, jack all happened. Remove the CPU, hit the power button, then quickly slam the CPU home: instant boot. Never had any problems other than that, and 'cos I only ever shut it down once in a blue moon I just kind of ignored the problem.
    Wish I'd kept that motherboard now.
  16. schmidtbag
    30 Jul 2010
    How did you manage to figure that out, and except for the comedic novelty, why would you ever want to keep something like that?
  17. none4you
    none4you What's a Dremel?
    15 Jan 2008
    NAS, Local WEB Server, Firewall, SAMBA, Print Server, PBX/VoIP Server, Streaming Server. .... it is rock stable and can run 24/365.
  18. schmidtbag
    30 Jul 2010
    I wouldn't consider a CPU that needs to be removed in order to boot properly rock stable...
    I also wouldn't consider a Pentium III build good to act as a server. I know it will perform all those tasks you mentioned just fine, but a Raspberry Pi could do all of those things in a much smaller space, in complete silence, with a fraction of the wattage.
  19. Vault-Tec
    30 Aug 2015
    Slot 2 was better. I always used to have two :D
  20. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Bugger. I was hoping they'd keep the mounting proportions so I could slap my Archon on without any fuss, I might have to look at getting a kit - I have no idea if Thermalright's later Archon kits even work for the original!
