at the mo i got a abit ib9 and an intel 2ghz core2duo, and i'v been seeing soem of the lastest games start to chunk a bit (burnout pardice, saint row 2) so i was wondering should i just throw a new cpu in there (max it can take is a E7300 2.66) or should i just get a new mainbord, cpu, ram ? please rember this pc is for gameing
Well i'm guessing you're playing at 1368x768. You'll be fine as you'll be raking in frames on most games fairly well and can push the AA a bit too. If you were going to upgrade though I'd say go and grab a new mobo + CPU( AMD PII X3 720BE + 790GX).
cpu http://www.scan.co.uk/Products/AMD-...ion-Sok-AM3-32GHz-8MB-Total-Cache-125W-Retail mobo http://www.scan.co.uk/Products/MSI-AM3-MOBO-790GX-G65 ram http://www.scan.co.uk/Products/4GB-...(1333MHz)-240-Pin-Unbuffered-CAS-9-9-9-24-DHX cooler http://www.scan.co.uk/Products/Arct...1156-S775-AM3-AM2plus-AM2-939-Up-to-130-Watts! total £319 extra money went on chip well worth the extra price, that system should keep you set for a while and all you have to do in the future is upgrade your gpu
