Windows XP and SB Platinum...
Discussion in 'Software' started by Koolvin, 25 Oct 2001.
  1. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    anyone get this combination to work???
  2. Cheese
    Cheese Doc
    6 Oct 2001
    Have problems using 5.1 speakers with my player 5.1 (software takes an age to load on startup). New drivers are due any second mind...
    r.
  3. Lordflash
    Lordflash What's a Dremel?
    27 Aug 2001
    Yep just install the drivers and not creatives live suit just liek the via chip set problems. That how i got mine to work
  4. Guest-16
    Guest-16 Guest
  5. primus
    primus What's a Dremel?
    27 Oct 2001
    My platinum 5.1 works fine with these drivers: http://www.soundblaster.com/support/winxp/
    But there is one problem with it, I can not get the center speaker to work whatever I do. If anyone has had the same problem and has found a solution, I would love to know how you sorted it . :)
    thx
