Corel Paint Shop Pro X Free You can get it Here To remove nag screen (on exit) do the following: 1. After installing, open the following file in Notepad: C:\Program Files\Corel\Corel Paint Shop Pro X\PCUUI\Container.htm 2. Erase all the text, replace it with the following code: <script type="text/javascript"> location="pcucmd://Cancel?confirm=no"; </script> Save the file ________ YOSELIN
I am happy with Jascs Soft Paint Shop Pro 7. Works perfectly under 2000, XP, Vista, Win7.. and I am not even at a point to run it in any compatibility mode. The only down side is the file associate doesn't work.. but I don't care. It opens just as fast as Photogalary in Windows
There is no catch and it is completely above board, I even posted the "fix" to remove the "nag" on exit... ________ Glass pipe
Excellent, I prefer Paint Shop over Photoshop as I have no need for so many features. Plus photoshop is easier to use.
I've been using PSP 7 for ages too and always been very happy with it. Just hoping this one allows you to crop an image to specific dimensions, ie so I can cut a section out of an image that will allow me to print it at 6x4. Thanks for the find Jbloggs.
Reminds me of a younger self but nowadays I prefer the easier option - unless you actually meant PSP is easier to use!
I was once a happy user of paintshop 6,7,8, and 9 then a photoshop CS2 disc appeared on my desk one day, and well i've been using that since. I did pirate CS3 so i could trial run it with all the features, but i just couldn't see the point with it and ended up going back to CS2. Paintshop pro X does look interesting.
I used to use PSP but since finding Paint.net I have had no need to go back to it. I didn't even bother to reinstall PSP after my last rebuild, ~20 months ago
I am one of the people that way back when got along better with photoshop, and since has stuck with it... CS2, CS3 and now CS4... all original...
