Other Best place to buy used slr and lens?
Discussion in 'Photography, Art & Design' started by obaidbd, 28 Nov 2014.
  1. obaidbd
    obaidbd Minimodder
    24 Jan 2012
    Hi Guys
    Just wondering what is the best place to look for used SLR camera and lens? apart from ebay.
    I am up for Canon 6D + may be EF 135mm as well
    EDIT: or even NEW with great price :D
  2. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    I have heard that the cheapest way to buya top end DSLR and Lens is to fly out to Swizerland and buy it there. It may sound odd, but it's possible to shave up to 25% off the UK price, even when you factor in the price of the flight. Flat pack the box and mail it home, and put the rest in your bag.
  3. GeorgeK
    18 Sep 2010
    wex photographic is a good place to look - they trade in and then sell on second hand equipment and give a 12 month warranty on it. I've bought a 2nd hand lens from them before and it's not missed a beat.
  4. silk186
    silk186 Derp
    1 Dec 2014
    Depends if you are looking to buy something from a shop or private sale, like a forum like dpreview
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    www.mpbphotographic.co.uk are one of the bigger pre-owned resellers. They are all really nice guys, all photographers and their kit is quite decently priced. It's where I get all my stuff from, can't recommend them highly enough.
  6. megamale
    megamale Minimodder
    8 Aug 2011
    Ha ha, yes I've done just that and nabbed a D750 for 40%. Check this thread:
    http://forums.bit-tech.net/showthread.php?t=278947
    It doesn't work for all the cameras, but it's worth investigating.
  7. obaidbd
    obaidbd Minimodder
    24 Jan 2012
  8. megamale
    megamale Minimodder
    8 Aug 2011
    Travelling to other countries is not convenient to anyone :D
    The thing to check with the ebay seller is whether it is a grey import. This would mean that the warranty is not from Canon, but from the shop. So you need to rely on them if something goes wrong. Also, the resale value will be affected if you cannot prove it's a proper Canon UK warranty.
    If you want to go the grey market route then use these guys:
    http://panamoz.com/index.php/canon-eos-6d-digital-camera-body-only.html
    I have never used them but they get decent reviews and seem quite reliaable in honouring warranties.
