Graphics GFX upgrade
Discussion in 'Hardware' started by ashikamlani, 6 Jul 2014.
  1. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    Hi all, I have an old dell computer lying around which I wish to repurpose as a gaming machine. It currently contains a Radeon 5770 and I wanted to upgrade this part as this seems to be the bottleneck at the moment.
    Given the limitations of the PSU (around 300W if I remember correctly) I was thinking a GTX 750 would fit the bill perfectly. The question I wanted to ask is if anyone can envisage any potential compatibility problems etc. before I currently go ahead and buy? Do I need to worry about PCI speeds etc.? I'm not actually sure what the motherboard is but the chipset is an Intel H57 I think. The CPU is an old i7.
    Thanks for the help
  2. ashikamlani
    11 Mar 2006
    Anyone?
  3. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    the wattage of the psu isnt too bad but more the quality, u should get a good quality psu as if this fail's it could take the sys down, but other than that a gtx 750ti would be a good choice.
    il try answer any more questions you have.
  4. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    only problem you mite have is your PSU wattage.
    As long you dont have loads of hard drives running you mite just get away with 300w
  5. Deders
    Deders Modder
    14 Nov 2010
    If the PSU can power a 5770 it shouldn't have much problem with a 750.
  6. Teelzebub
    27 Nov 2009
    Personly I would upgrade the PSU it certainly would be close, you could pick one up in the MP
    Does Dell use a standard size PSU though? You may want to check that first.
  7. ashikamlani
    11 Mar 2006
    Thanks for all the advice. Ideally I wanted to try and not have to upgrade the PSU if possible (purely for financial reasons). I believe the wattage should be ok as a 5770 uses more than a 750 gtx.
    But there should be no other issues I assume?
  8. mrbungle
    20 Sep 2004
    Dell PSU's are fairly hardy, a low wattage GPU like the 750 should be ok imo.
  9. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    I would recommend a PSU upgrade.
    Although it may work, as you've said, the psu is older.
    Efficiency degrades over time.
    Simply not a good idea to underpower any system.
    750-750Ti range card would be a good upgrade.
