CPU The E5200 Successor
Discussion in 'Hardware' started by jazzzyj, 1 Dec 2009.
  1. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Ok , for a while the old E5200 was the chip of choice for the sub £100 market.
    I've finally gotten round to looking for a replacement for my E2180 and I can't find these chips in the shops!
    So what is next? Is there another chip for the same sort of price (£50-80ish) that has a good overclock like the E5200 or have I missed a shop that still does them?
    Thanks
    -J
  2. smc8788
    smc8788 Multimodder
    23 Apr 2009
    The E5200 was replaced by the E5300, which now seems to have been replaced by the E5400.
    While at the higher end of your price range is the E7400.
  3. Krikkit
    21 Jan 2003
    OcUK and Tekheads both have an E5200/E5300 in stock, although if you've got a bigger budget you might want to look at something like an E7400. :)
  4. javaman
    javaman May irritate Eyes
    10 May 2009
    I would look for a quad. Might as well take a huge step and save upgrading for abit longer. Only problem is would your budget stretch to it?
  5. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    I've got an E5200 kicking about - rare use, but went to 3.8GHz. Can check if it's still sitting in an old mobo if you like?
  6. retrogamer1990
    retrogamer1990 What does 'Stock' Mean?
    12 Jan 2009
    you can pick up a used Q6600 off forums for about £80 nowadays if thats any good :)
  7. MaverickWill
    26 Apr 2009
    I've got one of them, too - it's going back in my Shuttle. xD
  8. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
  9. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
  10. TheBlackSwordsMan
    16 Aug 2009
    The Important Word is 'Celeron' :waah:
  11. play_boy_2000
    25 Mar 2004
    it's still a wolfdale core, which is the best core intel has ever produced imho.
  12. MaverickWill
    26 Apr 2009
    *coughNehalemcough*
  13. play_boy_2000
    25 Mar 2004
    After its all said and done, wolfdale will probably outsell Nehalem by at least a factor of 10 (excluding westmere).
  14. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    No L3 Cache is a CPU killer.Anyway a Dual core Nehalem cpu would be quite amazing ( 4.7GHz on air would be a superPi destroyer )
  15. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Interesting stuff.
    I may have to look second hand then. I was always after a Q6600 but I figured that as they aren't being sold new, people would be holding on to them a bit longer.
    What should I be looking out for behind these numbers.
    e.g L3 Cache is important?
    I think I shall be having a shufty around the classifieds.
    -J
  16. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Right so.
    Now that the Christmas rush is over, I can get looking for a chip.
    Anything I need to look out for?
    -J
  17. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Got me A E6300 2.8Ghz chip now.
    That has certainly bumped up the scores!
    -J
  18. capriboy
    capriboy 42
    13 Jan 2010
    and if your really lucky the person you buy it from won't try to rip you off....
