Graphics R9 290 v GTX 970
Discussion in 'Hardware' started by DraigUK, 30 Sep 2014.
  1. DraigUK
    DraigUK Minimodder
    9 Apr 2009
    I notice on EBuyer the price of the MSI R9 290 has had £90 knocked off it with other cards also having big cuts.
    So, given I can pick up a MSI R9 290 for £254 which should I get? The MSI NVidia GTX 970 for £275 the MSI R9 290 for £254???
  2. Teelzebub
    27 Nov 2009
    I'd go for the 970
  3. bartiszon
    bartiszon Minimodder
    25 Aug 2010
    Same here - gtx 970.
  4. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    The 290 is going down all over now.
  5. DraigUK
    DraigUK Minimodder
    9 Apr 2009
    Can you guys explain why you would go for the GTX 970? From what I can find the R9 290 seems to perform better and is now cheaper by some margin?
  6. johnim40
    johnim40 Minimodder
    23 Apr 2009
    hi the 970 is newer cooler and lower power
    all plus
  7. Snubbs
    Snubbs CustomPC Migration victim....
    27 Mar 2009
    The nVidia card is cheaper to run as it uses less power, and is more stable as far as drivers etc are concerned.
    I've got a 290X, and personal experience of it so far is that some driver releases from AMD are terrible. 14.4 I had quite a few BSOD's with. 14.7rc3 seemed stable, and I've just installed 14.9 - we'll see how that goes.
    The nVidia card will also be quieter if you're looking at the reference design 290. My 290X sounds like a vacuum when I'm gaming.
  8. Kovoet
    26 Aug 2009
    The 290 performs very well but if it's got the reference cooler and you going to stick with a reference cooler I'd go with the 970. The new 3xx AMD series will be lout soon as well.
    Problem with the 290 it's loud and gets hot.
  9. The_Crapman
    5 Dec 2011
    From the reviews I've seen, 290 only ever beats the 970 @4k and only in a couple of games. 970 beats the 290 in most circumstances and being newer, will make use of newer technologies and five better longevity. Plus it's cooler, quieter, more power efficient and overclocks like a beast.
    Kovoet likes this.
  10. David
    7 Apr 2009
    The 290X might out-perform a 970 in some games but I don't think a vanilla 290 will beat a 970.
    The 970 is faster, cooler, quieter and less hungry.
    Kovoet likes this.
  11. DraigUK
    DraigUK Minimodder
    9 Apr 2009
    Ah well just ordered two of the MSI 970 from Scan. Hopefully a good decision.
    Thanks all for your input.
  12. Kovoet
    26 Aug 2009
    Good choice
