Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 23rd Sep 2016, 20:33   #1
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Can you cut LED strips?
I'm sure I read that you can. Thing is I am worried about cutting them in the wrong place and killing them.
So can you? and if so if I upload a pic could some one tell me the cut points?
Cheers
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 23rd Sep 2016, 20:36   #2
Goatee
Hypermodder
Goatee's Avatar
Goatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming Saiyan
Yes, typically you cut them at the gold connectors (then strip the plastic sleeve off at those points) and solder or use one of these: http://www.theledstore.co/led-strip-connectors-FSCT-010%20RGBW?gclid=CKe-1o6eps8CFegp0wodUOECSg
Goatee is offline   Reply With Quote
Old 25th Sep 2016, 00:24   #3
Vault-Tec
Vault-Tec's Avatar
Mine are not like that fella. I will try and get a pic of the back side/traces tomorrow. They were like 1.12 for two lol. IIRC it's three LEDs per resistor, so it should be manageable.
__________________
MUWC Winner ROTT
Old 25th Sep 2016, 23:54   #4
Vault-Tec
Vault-Tec's Avatar
Any idea if they can be cut?
__________________
MUWC Winner ROTT
Old 26th Sep 2016, 00:09   #5
Vault-Tec
Vault-Tec's Avatar
NVM figured it out. You can cut them
__________________
MUWC Winner ROTT
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
