Old 6th Oct 2016, 09:57   #1
JessePalacio
Modder
JessePalacio has yet to learn the way of the Dremel
project SINAW
Hello,
its been a while since i last posted here. i am back now with a project for an invitational case modding competition hosted by Cooler Master for some modders in the Philippines. I will be modding with Mhike Samsin, Kryptek Modz and new but not so new comer, MadModz Mickey Lacerna. this will be fun.
build logs along with an explanation of what im gunning for in this build, within the next day or two.
stay tuned.
-JPModified
JessePalacio is offline   Reply With Quote
Old 6th Oct 2016, 10:11   #2
jojoharalds
Supermodder
jojoharalds's Avatar
jojoharalds has yet to learn the way of the Dremel
Rule Number 2 on Bit-tech:
2. Your first post must show work in progress, not just a heap of parts and some rough sketches. If you have no physical modding to show, wait until you do or start your log in the 'Modding' forum. In this case, once you do start physical work, request that the project be moved to the project log forum by contacting a mod or emailing modding@bit-tech.net. The general idea here is to maintain the high quality content we’re all used to.
jojoharalds is offline   Reply With Quote
Old 6th Oct 2016, 10:14   #3
JessePalacio
Modder
i'll take it down
edit: apparently i cant.. or dont know how to. emailed bit-tech. thanks
Old 6th Oct 2016, 10:21   #4
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Moved to 'Modding' until there's work to show, no problem JessePalacio!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
