Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 14th Nov 2016, 18:22   #1
mxdout
What's a Dremel?
mxdout's Avatar
mxdout has yet to learn the way of the Dremel
The Pink Chill
THE PINK CHILL!
Hi everyone!
The MxdOut team will be constructing an office build, with different builds to fit the different requirements of each individual within the office. For example, our graphics designer would need a PC compatible with many different designing programs, would need a screen with the best resolution, would need a large drive with a large memory, a fast processor, etc. We would like to custom wrap each PC we builds to match the personality of whomever the build is for. The idea is that we will be able to show people how to make super cool looking PC’s, as well as showing them the components needed to create certain kinds of PC’s to match whatever criteria they need to meet.
We want to show cable management inside and outside with the monitors and speakers all connected so that people can get a better understanding of how things will look when they’re finished. We want to show that custom computers can be easy and comfortable to make, and we want to allow others to see the right ways to set up their office, desk space, etc. on a bigger scale.
For this build we will have a white case with pink insides for our webdesigner - hence the name, 'The Pink Chill'
Check out some of our other builds below
Super Silent Intel Skylake Build - https://youtu.be/fqAYxfALsW4
Silverstone and Intel Haswell Budget Build - https://youtu.be/9jifmVC-0IE
One of the best computer builds this year! - https://www.youtube.com/watch?v=PgOd...OnCMLK1TA&t=1s
mxdout is offline   Reply With Quote
Old 17th Nov 2016, 15:54   #2
mxdout
What's a Dremel?
mxdout's Avatar
Acrylic Tubing
Acrylic Tubing from Bitspower
Old 18th Nov 2016, 12:17   #3
mxdout
What's a Dremel?
mxdout's Avatar
3 different sized radiators from BitsPower ready to go into our build
Old 18th Nov 2016, 19:10   #4
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Moved to modding until there are pics of work actually in progress.
GeorgeK is online now   Reply With Quote
Old 26th Jan 2017, 13:44   #5
mxdout
What's a Dremel?
mxdout's Avatar
InWin 303 Custom Pink Chill PC Build! - The Office/Gaming Computer Build Series | 1
So at last, the long awaited FIRST build of FIVE is complete! We're logging the whole thing on our YouTube channel, where you'll be able to watch a six episode series of how we build and what we use in the builds to complete our Office Build project!
Today we have the Pink Chill for you, and this computer is being built for our web-designer.
BUILD PROGRESS:
FINISHED BUILD VIDEO:
PRODUCTS USED:
⭐️ Noctua - Fans
💸 http://noctua.at/en/products/fan
⭐️ #BitsPower - Acrylic Tubing
💸 http://www.bitspower.com/html/produc...oducts_id=4104
⭐️ BitsPower - White Compression Fittings
💸 http://www.bitspower.com/html/produc...oducts_id=3425
⭐️ #MSI - Z17A SLI Plus Mother Board
💸 https://www.msi.com/Motherboard/Z170...#hero-overview
⭐️ #Mayhem - Distilled Water
💸 https://www.overclockers.co.uk/mayhe...wc-102-mh.html
⭐️ Mayhem - Pastel Perfect Pink Concentrate
💸 https://www.overclockers.co.uk/mayhe...wc-056-mh.html
⭐️ #Akasa - Magnetic LED strip lights
💸 http://www.akasa.co.uk/update.php?tp...del=AK-LD05-50
⭐️ #EK - FC1070 GTX BackPlate
💸 https://www.ekwb.com/shop/ek-fc1070-...ckplate-nickel
⭐️ EK - FC1070 GTX WaterBlock - NIckel
💸 https://www.ekwb.com/shop/ek-fc1070-gtx-nickel
⭐️ #Ballistix by Crucial DDR4 memory
💸 http://uk.crucial.com/gbr/en/bls4g4d240fsc
⭐️ Bitspower D5 MCP655 Mod Top
💸 http://www.bitspower.com/html/produc...oducts_id=1424
⭐️ BitsPower D5 MCP655 Mod Kit
⭐️ #Crucial SSDs MX300
💸 http://uk.crucial.com/gbr/en/ssd/series/MX300
⭐️ Crucial SSDs MX200
💸 http://uk.crucial.com/gbr/en/storage-ssd-mx200
⭐️ #Intel i7-6700K Processor
💸 http://ark.intel.com/products/88195/...Hz?wapkw=6700k
⭐️ #EVGA SuperClocked GeForce GTX 1070 Graphics Card
💸 http://www.evga.com/products/product...08g-p4-6171-kr
⭐️ BitsPower Hexagon Water Tank
💸 http://www.bitspower.com/html/produc...oducts_id=4770
⭐️ BitsPower CPU Water Block Top Acrylic
⭐️ BitsPower CPU Water Block Top White
⭐️ BitsPower 360 Radiator
💸 http://www.bitspower.com/html/produc...oducts_id=3984
⭐️ BitsPower 120 Radiator
💸 http://www.bitspower.com/html/produc...oducts_id=3982
⭐️ TouchAqua 120 Radiator
💸 http://www.touchaqua.com/index.php?m...oducts_id=4406
⭐️ EK - Pump
💸 https://www.ekwb.com/shop/ek-d5-pwm-...pwm-pump-motor
⭐️ #InWin 303
💸 https://www.inwin-style.com/en/gaming-chassis/303
TOOLS USED:
🛠 Monsoon - Hardline Pro Mandrel Kit
💰 https://www.overclockers.co.uk/monso...wc-202-mo.html
🛠 Monsoon - Hardline Pro Cutting Kit
💰 https://www.overclockers.co.uk/monso...wc-205-mo.html
🛠 Dremel - Multi-Tool
💰 http://www.diy.com/multi-tools-hobby.../262087_BQ.prd
🛠 Dremel - Cutting Disks
💰 http://www.diy.com/departments/dreme.../213577_BQ.prd
🛠 Dremel - Drill Bits
💰 http://www.diy.com/departments/dreme.../190548_BQ.prd
🛠 Dremel - 100pcs Mixed Accessory Kit
💰 http://www.diy.com/departments/dreme...1248752_BQ.prd
🛠 Rolson - 28 pcs Offset Screwdriver Set
💰 http://www.maplin.co.uk/p/rolson-28-...iver-set-n46ju
🛠 Earlex - Heat Gun
💰 http://www.homebase.co.uk/en/homebas...eat-gun-117025
Reply
Tags
build, custom, modding, mxdout, watercooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
