Koolvin Unable to send you a reply to your last email? Get this Error? ----- Transcript of session follows ----- 554 Too many hops 26 (25 max): from <glen@gtonline.net> via serv162.ghoulnet.com, to <Koolvin@bit-tech.net> Reporting-MTA: dns; serv154.ghoulnet.com Received-From-MTA: DNS; serv162.ghoulnet.com Arrival-Date: Mon, 14 May 2001 08:56:49 -0400 Final-Recipient: RFC822; <Koolvin@bit-tech.net> X-Actual-Recipient: RFC822; Koolvin@bit-technologies.net Action: failed Status: 5.0.0 Last-Attempt-Date: Mon, 14 May 2001 08:56:49 -0400 Unless You actually got the reply?
Our hosts were carrying out a series of upgrades to their services last night, and as such e-mail has been up and down since about lunch time today. All seems good and well now though.
Still getting Bounced This is a MIME-encapsulated message -------------------------------------------------------------------------------- The original message was received at Mon, 14 May 2001 11:28:32 -0400 from serv162.ghoulnet.com [213.38.74.162] ----- The following addresses had permanent fatal errors ----- Koolvin@bit-technologies.net expanded from: <Koolvin@bit-tech.net> ----- Transcript of session follows ----- 554 Too many hops 26 (25 max): from <glen@gtonline.net> via serv162.ghoulnet.com, to <Koolvin@bit-tech.net> -------------------------------------------------------------------------------- Reporting-MTA: dns; serv154.ghoulnet.com Received-From-MTA: DNS; serv162.ghoulnet.com Arrival-Date: Mon, 14 May 2001 11:28:32 -0400 Final-Recipient: RFC822; <Koolvin@bit-tech.net> X-Actual-Recipient: RFC822; Koolvin@bit-technologies.net Action: failed Status: 5.0.0 Last-Attempt-Date: Mon, 14 May 2001 11:28:32 -0400 Please let me know what the score is?
Well, if you remember the site was down for a few days a couple of weeks ago. We then switched to new hosting, and moved one of our domains (www.bit-tech.net) to the new host. It would seem that if you are getting errors such as: Reporting-MTA: dns; serv154.ghoulnet.com Received-From-MTA: DNS; serv162.ghoulnet.com and 554 Too many hops 26 (25 max): from <glen@gtonline.net> via serv162.ghoulnet.com, to <Koolvin@bit-tech.net> Then you're DNS might need to be updated, as the bit-tech.net is no longer hosted with ghoulnet.
Sorted Worked fine from home, me thinks? Thanks for the friendly advise peeps Didn't expect anything else. Big up yourself boy's. Spending more time in this Forum than I do for the one I moderate!
there are no messages in the logs saying it bounced. I am guessing ghoulnet still has bit-tech setup somewhere in DNS 554 Too many hops 26 (25 max): that appears to be the error. i'm guessing there was a loop back somewhere on the ghoulnet network seen as they were being used as the SMTP server gonna ask ghoulnet if they still have anything still setup on their servers for bit-tech.net and gonna them a copy of the session transcript Hmmmmmmmmmmmmmmmm
