Scratch Build – In Progress Project Flipmode - 1 jan 2012 - Flipmode finisht -
Discussion in 'Project Logs' started by Paslis, 13 Jun 2011.
  1. Paslis
    Paslis Minimodder
    13 Jun 2011
    Hi Everyone,
    Allow me to introduce myself.My name is Pascal and i am from the netherlands and i am a metalworker/welder for 22 years now.I am infected with the mod virus and after building 2 desks http://gathering.tweakers.net/forum/list_messages/1439066 its time for something else.This time its gonna be a tower and again build from scratch.
    The name of this project is Flipmode.
    The drawnings.
    The idea is to place the mobo under 45 degrees and putting the pump and reservoir behind the front.I also gonna use 2 koenigsegg doors in this project.
    Sponsors :
    Hardware :
    Proc : i5 750
    Mobo : Asus P7P55D
    Mem : 8gb corsair dominator 1600c8
    Vid : ATI Radeon 4870x2
    Sound : Onboard
    Hdd 1 : OCZ vertex 2 60gb
    Hdd 2 : WD raptor 150gb
    Hdd 3 : WD raptor 150gb
    Psu : Cooler Master Silent Pro Gold 800W
    Cooling :
    Pump : Laing DDC-1Plus MCP355 + Bitspower top
    Rad : EK Coolstream XTC 420
    Res : Custom
    Vga : Bitspower black freezer
    Cpu : EK Supreme HF
    Mem : Bitspower galaxy freezer
    The hardware I'm still collecting.The material I will use will be a combination of steel and aluminum or stainless steel.The color of all I have in my head but as the build progresses can still change.The goal is to make everything as clean as possible to show.
    Now it's time to start the project.
    The Frame.
    Cutting the frame.
    The cutting work is completed so now its time to putt it together.
    Below I have 4 right-angled corners welded.
    The sides.
    The sides are ready now so I will compile the entire frame.
    The frame is finished so now its time to make the plates for the levelers.
    The frame is finished.
    The frame is finished, so now its time to make the custom hinges for the Koenigsegg doors.
    The drawings of custom hinges.
    I hope you can understand my dutchy english.Untill the next update.
  2. Mystikal0412
    Mystikal0412 Safety First, Think Twice!
    31 May 2011
    English is good enough! It's the modding what counts! Was also following you on Tweakers! Keep up the good work!
  3. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 1 - 14 jun 2011
    Today I started working with the plating.I chose for aluminium to make the case not to heavy.
    First i cut the aluminium to the size i need.
    The corners cut out.
    Draw the holes.
    Dril and sink the holes.I grapped a m4 bolt and adjusted the dept.
    I also made the cover that i will place behind the frontpanel.
    Now its time to compile everthing.
    This was it for today.
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    Was following your work also on tweakers.Keep up the good work to.
  5. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    love it love it love it =D
    this makes my swedish koeninsegg heart bleed tears of ioy =D
  6. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Nice work bench. I am jealous. I always wondered how they made those hinges. I will be watching!
  7. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    Welcome to bit-tech, this is a great community of artist, modders,sculpters and PC builders and we welcome another great builder to the class.
    I like your plans for your project and your shop is amazing.. I can't wait to see this develop.
  8. Shael
    Shael What's a Dremel?
    19 Jan 2011
    Ahh another scratch build involving steel and welding:thumb: will be definately following this and i cant wait to see how those hinges come together:idea: - subbed
  9. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    Nice work so far. :thumb: I'm looking forward for more. :)
  10. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you and my dutch heart bleeds tears of joy to when i see the koenigsegg. :)
    Thank you and you will see them soon.
    Thank you and it isnt my shop but its the shop of my boss but i have a key and i can use it whenever i want.
    The hinges will be finisht soon.
    Thank you. :)
  11. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 2 -16 jun 2011-
    Today i did some drawning and afcouse some modwork.
    First i drilled some holes from 3,5mm then tapped with a tap m4.
    Then I started working with the backside.
    Drilling the holes for the backplate.
    I had a backplate from another build so this one im gonna use.
    A piece of 5mm plexi drilled some holes in it and tapped them.
    Putting it together with m4 bolts but they are temporarily because i will replace them for black sunk bolts.
    Not its time to fit the parts in the frame.
    I was wondering how much the case weighs at this point so i putt it on a scale and it already weighs 12 kg.
  12. Herculess
    Herculess What's a Dremel?
    5 Oct 2010
    great welding job you made! keep modding and i will watching your work my friend!
  13. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    I was thinking he must be a welder :cooldude: Very nice work :thumb:
  14. (FIH) The Don
    (FIH) The Don What's a Dremel?
    27 Jun 2010
    o love how you turned the MB just a bit :D
    definately gonna be watching this one
  15. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you and i will keep on modding.
    Your correct im a welder. :)
    Turning the MB gives allot of extra space.
  16. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 3 - 19 jun - 2011
    Time for some modding.The hinge is ready so its time to putt it in place.
    The hinge is made of stainless steel and the bearings are made of brass.The axle is also made of stainless steel.
    Drilling the holes for the hinge.
    Placing the hinge inside the cover.
    Now its time to make the frame for the door.For this im gonna use aluminium 20x20x2mm.Everything is measured out so the sawing can begin.
    The sawing is finisht so not its time to compile the door.
    Some finishing.
    Then i made a plate for the axle with 2 m4 holes in it and weld it on the frame.
    Then i made the same plate out of stainless steel and screw it on the aluminium plate.
    Then i measured everything out and welded the axle on the plate.
    It fits perfect and works like a charm.
    enormous likes this.
  17. Cheapskate
    13 May 2007
    :clap: Excellent work, and welcome to Bit-tech.:D
  18. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Heey u here also! :D
    Nice to see u here buddy, Keep on going :D!
  19. Karrek
    Karrek Minimodder
    7 Jun 2011
    Very nice door. Never seen that done in a computer (or much else for that matter). Is there much flex or play in the hinge? great job!
  20. bulldogjeff
    2 Mar 2010
    Thats some nice metal work skills you've got. looking good so far. I was wandering about the weight also, but you've answered that. It going to get a lot heavier by the time it's finished...lol
