Recently reinstalled Win 7 and my pc keeps firing itself up with no input. I have disabled every network wake event but it keeps doing it. Anyone got an idea?
The thing is it's only started doing it since I reinstalled windows about 5 days ago, I did update all the drivers to the latest ones so I'd imagine that's introduced something.
I had this issue.. it was the router broadcasting something. Couldn't be disabled, and never did resolve it.
powercfg You could try using powercfg to determine what can cause the machine to wake up. Code: powercfg -devicequery wake_armed ...or use... Code: powercfg -lastwake ...to see what caused it to come out of sleep. There are more details on http://technet.microsoft.com/en-us/library/cc748940%28v=ws.10%29.aspx.
I forgot to mention that you can also use... Code: powercfg -devicedisablewake "item" ...to prevent it waking the machine up once you've narrowed it down. I suspect you could also use its entry in device manager too (Power Management > Allow this device to wake computer).
Aha that's really useful to know, next time it does it, I'll try that bit of code to see what woke it up. Thanks.
You could try this. Open 'Device Manager' and navigate to 'Mice and other pointing devices' and double click to open it. Double click on the entry for your Mouse then click on the 'Power Management' tab. Remove the tick from 'Allow this device to wake the computer'.
