A/V soundbar over speakers ?
Discussion in 'Hardware' started by stormbringer500, 13 Apr 2015.
  1. stormbringer500
    stormbringer500 What's a Dremel?
    6 Jan 2010
  2. Mister_Tad
    27 Dec 2002
    Whilst I'm not able to offer a great deal of constructive input specific to the question, you might get some better advice if you can post whether it's for primarily music, films games and budget/space constraints and what inputs you require.
    FWIW soundbars tend to be for scenarios where you can't accommodate "real" speakers, and are often compromised in comparison. In comparison to the Z2300s though, this could be different.
  3. stormbringer500
    6 Jan 2010
    Well I would be using for films, TV and games mainly also would not say space is a issue I was just wondering if a sound bar is the way forward as oppose to speakers.
    My budget would probably be up to £150 ~
  4. bulldogjeff
    2 Mar 2010
    Have to agree with this. They are a bit of a compromise.
    The sound bars with a separate sub aren't to bad though. At least it has a decent amount of base.
    As a personal thing. I would always go for separates.
  5. mrbungle
    20 Sep 2004
    £150 is a small budget for a soundbar, I would expect them all to sound fairly meh at that price range.
    £150 in 2nd hand seps could be super though :)
  6. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    I'd definitely vote for separates. You could pickup a decent 2nd hand system for around £150 (perhaps a used Onkyo all-in-one or similar).
    You could always start with a better amp and two fronts for your £150 budget, then expand to 5.1 as funds allow...
  7. silk186
    silk186 Derp
    1 Dec 2014
    for £150 you could buy a nice 2.0 or 2.1 set of speakers. I've never heard a nice soudbar.
    m-audio av40
  8. ak_2020
    ak_2020 Minimodder
    22 Nov 2010
    +1 for the separates.
    Soundbars are by their very essense a compromise...so if you are wiling to put in a bit of extra effort a proper 2.0 or 2.1 set-up will be far superior.
    I've heard (pun intended) good things about Microlabs. For the same money as the soundbar you've picked out in your OP you could get a set of Microlab Solo6c. Never heard them myself but appear to be pretty highly rated.
  9. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Yes, separates are the way to go. Try looking on the classified section of the avforums.
  10. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
  11. wyx087
    15 Aug 2007
    I don't think soundbars are compromise.
    But I'm comparing top of the range Yamaha Vs my years old Logitech gaming set. :p
    Anyway, yes, I think for that budget, I'd have separate speakers.
  12. stormbringer500
    6 Jan 2010
    I am seeing those Microlabs and they look really nice, just a bit big.
  13. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    16cm x 11cm x 8cm
    That's tiny for speakers.
  14. JamesRC
    JamesRC Minimodder
    5 Oct 2012
  15. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    removed - wrong URL!
  16. stormbringer500
    6 Jan 2010
    Unfortunately although its cheaper still would cost me £69 because Scan charge the Highlands £12.99 carriage >.<
  17. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    There are used-VGC Amazon Warehouse deals @£55, probably worth a punt.
  18. ak_2020
    ak_2020 Minimodder
    22 Nov 2010
    sorry to be pedantic, but thats the Solo 1C, which is a lower spec (60w vs 100W for the 6Cs)
    I'm sure its still a good speaker, mind...everything I hear about Microlabs is overwhelmingly positive!
  19. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
  20. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    Whoops, thanks for that... post edited.
