Hardware AMD Opteron 6174 vs Intel Xeon X5650 Review
Discussion in 'Article Discussion' started by Sifter3000, 31 Mar 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    I'm hoping this line isn't a misprint
    6128 2GHz 8 80W 1,333, 1066, 800 $266
    Though the motherboards are FAR from economical (in regards to a specialty case requirement, and high set up costs), 8 physical cores at 2GHz a piece is a rather INSANE value for $266.
  3. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    No, it's not a misprint, but don't forget that $266 is the list price, so what you end up paying (depending on where you buy it) won't be exactly the same as this. It's a great price even so :)
  4. confusis
    confusis Kiwi-modder
    5 Jan 2006
    looks like folding has a new king... might be time to save for a amd 6174setup!
  5. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    you got the Xeon table wrong - the logical cores column
  6. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Was I the only one who thought the Picture was stretched when they first saw the Opteron?
  7. Tulatin
    16 Oct 2003
    Even if it hits the deck for $299 retail, it's still a fantastic deal if you think about it. It would really open the door to rather ridiculous performance, when you consider that you could probably build a 16 core, 32GB of ram rig for a shade under 5k.
    I'm curious as to those motherboards, though. Judging by the haphazardly placed pci-e slots and giant motherboard gaps, I assume there's I/O risers, or?
  8. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Made good reading and great to see Bit-Tech covering something for the dual CPU enthusiasts, especially as i just got a couple of X5650's :)
    I'm currently running mine in an Intel S5520SC Shady Cove board running BIOS update 48 and getting in the region of 36014 in Cinebench R10 to your 32724 which is quite a large increase.
    I'll run a few more of the benchmarks you ran and see how they compare.
  9. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    What do you think is incorrect in the table?
  10. Tulatin
    16 Oct 2003
    It may be difficult to utilize a CPU with 0 logical cores.
    L5609 1.86GHz 4 0 40W 1,066, 800 $440
  11. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    With this many threads available I'm curious how would two or more "heavy" applications run on these...
  12. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    No, the table is correct. This CPU does have 4 physical cores but doesn't support Hyper-Threading so doesn't have any logical cores.
  13. Tulatin
    16 Oct 2003
    Makes sense. Can you add an * to it in the article, and clarify this to deal with further confusion?
  14. barndoor101
    25 Oct 2009
    ahhhhhhh right, you were doing it in addition as opposed to giving the total - normal nomenclature is to give the total physical cores then the total logical cores, that way you can easily tell if the CPU has HT.
    a single physical core without HT is still a single logical core :thumb:
  15. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Good idea, I've added an addendum underneath the table to hopefully avoid any confusion over this issue.
  16. Doomah
    Doomah What's a Dremel?
    8 Oct 2009
    About the X5677. The reason it's higher clocked but less cores is simple: Some server software is 'pay per core'. So if your server has less cores, you pay less for the software. So instead of taking a slower 6 core, you actually save money by taking a faster quadcore.
  17. barndoor101
    25 Oct 2009
    its probably more to do with certain applications not scaling above 8 threads - so having 8 faster threads is more desirable than ahving 6 slower ones.
  18. unclean
    unclean SMP obsessive
    30 Dec 2003
    Guys, the explanation of why the Opteron is so much faster in Cinebench R11 is flawed. Although there is some element of truth regarding the lower clocked cores, as there is more overhead associated with actually executing each thread, that can be said of R11 too. The difference is really due to the 16 thread limit present in Cinebench R10.
    I don't know, it seems like nowadays there's an element of thorough analysis that's missing and results are rushed online.
    Same for the 470 & 480 reviews. Arguably, the 480 *is* the fastest single card, not by much of a margin, granted. However, to give the 470 lower ratings (mainly regarding value) than the 480 seems absurd, as it clearly represents much better value for money.
    I feel like a parent saying "I'm not angry, just disappointed"...
  19. venommachine
    venommachine What's a Dremel?
    31 Mar 2010
    Post by; Tulatin:
    The Supermicro UIO boards come with various different PCI-E Risers, to go in either 1U or 2U form factors. Supermicro of course have DP Workstation solutions available also for mid-tower or workstation form factors for personal supercomputing.
    Boston Limited, where the test kit came from, are the guys who know all :)
    JW
  20. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Good point, sorry about that - I've been trying to write the Opteron 6000-series, Xeon 5600-series and forthcoming Xeon 7500-series reviews together, and had overlooked the thread limit in Cinebench R10.
    This isn't the right place to discuss this, as there's two dedicated threads for the GTX 470 and 480, but just because something is cheaper doesn't mean it's better value for money.
    Value for money is an indication of the balance between performance/features/price - not just an indication of how cheap a product is.
Tags: Add Tags
