Scratch Build – In Progress Cray-1
Discussion in 'Project Logs' started by Pfaffen, 19 Jan 2010.
  1. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    I had an idea to make a scale version of a truly remarkable computer, the Cray-1.
    Here is the idea on paper. You'll notice it was designed to support two complete computers (mobo, psu, dvd, hdd, etc...)
    Here is the lay out on plywood. I plan on covering the lower part with Naugehide, like the original, so the plywood won't show through. Also, it is lighter than MDF or solid wood.
    Here are the roughed in lines
    another shot
    Here is a shot with the Mobo and placeholders laid out
    Here are the cutouts.
    top and bottom
    here they are together with the spacers
    Here is a shot with the vertical pieces in place, dry-fit together.
    Here is a view from the back.
  2. Pfaffen
    18 Mar 2007
    Sorry, wrong last pic.
    Here is the back.
  3. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Nice. Any chance of installing Acrylic windows so you can see the guts of the system?
    Like this:
    Also, do you plan to keep the original Cray -1 colors?
  4. Pfaffen
    18 Mar 2007
    I was playing with the idea... may just do that.
  5. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Sweet. Supercomputers used to be built with so much more soul back in the day, things like Jaguar now are nothing more than big server farms. I miss monsters like the Cray-2, that needed coolant that costs $300 a gallon and still had a waterfall of it just because it looked cool...
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    Why do you use multiple optical drives? A single USB-DVD would do it aswell, no?
    Other then that, this is going to be huge :eeek:
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    very cool idea
  8. Cheapskate
    13 May 2007
    Thee tower area just screams for radiators. *hint*
  9. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    WOW! Super Computer Super huge.
    I hope you have a Super large desk to put it on.
  10. jhanlon303
    7 Sep 2006
    The cable management will be a problem since a Cray's wiring is measured in 0.01 mm and done with individual wires because of timing requirements. I interviewed with Seymour Cray in 1981. Brilliant engineer.
    The insides:
    /edit
    Excellent idea by the way!
  11. Shadow703793
    5 May 2009
    ^ Damn never knew that. Must have been a huge PITA to upgrade/fix.
  12. Breach
    Breach Modding in Exile
    20 Jun 2005
    Very cool! The Cray 1 is probably my all time favorite old time computer, this will look awesome sitting beside a desk.
    And good start, it already looks the part
  13. Pfaffen
    18 Mar 2007
    I had planned on one dedicated for each system. Wasn't sure I could slave a USB-DVD between them.
    The overall dimensions are roughly 35" across and 25" tall. I does take up a lot of space though. May have to make a special stand for it.
  14. Pfaffen
    18 Mar 2007
    I know... I have been toying with the idea. There is soooo much space in there!
  15. Pfaffen
    18 Mar 2007
    Thank you very much. I am envious. You have met and interviewed a truly brilliant man. I researched alot for the project and found he (Mr. Cray) had hired women (seamstresses) if I'm not mistaken to handle the myraid of individual wires to minimize the distance travelled.
    I hope I can do justice to such an extraordinary computer.
  16. Pfaffen
    18 Mar 2007
    Here is a shot of the back of the Cray at the Smithsonian in DC.
  17. jhanlon303
    7 Sep 2006
    I see your problem - it's the blue wire! - Field Engineer
    Each of the early Cray computers were shipped with a dedicated Field Engineer( job they wanted me for). The engineer was hired when the order was placed and ONLY knew one box - his/hers.
    The FE lived with the unit as it was being assembled, transported, installed, first boot, and turn over to customer. Serious money for serious dedication. Hardware and Unix software.
    Bad_cancer likes this.
  18. The_Beast
    21 Apr 2007
    Very cool little fact
  19. confusis
    confusis Kiwi-modder
    5 Jan 2006
    jhanlon303 - knows all, imparts wisdom in all he speaks to!
  20. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Still done, with stuff like Radars.
