Help re 2 GPU's
Discussion in 'bit-tech Folding Team' started by Taffy, 12 Apr 2013.
  1. Taffy
    Taffy Folding for Margaret 17/3/2011 RIP
    23 Apr 2009
    I have just set up my main computer for folding, it has 2 GPU's type 275's However this installer only recognises one of them can someone tell me how to start the second one ( it does not have a Monitor on it but this worked Ok before. the 275 that has been accepted has a "Paused waiting for idle" in yellow on it. can you give me an explanation for this? many thanks Taffy.
  2. RedFlames
    23 Apr 2009
    'paused: waiting for idle' means exactly that, it's waiting for the PC to be idle before folding
    set 'Folding Power' to 'Full', iirc it defaults to medium which folds on CPU on all bar one core, and only when idle on the GPU.
    as for the seconds GPU have you tried adding a second GPU slot manually?
  3. Taffy
    23 Apr 2009
    Hi red Flames, it appears that I have to add the 2 GPU's in the old manner which I have now done the 275's being that ancient (like Me) :lol::lol: The Alien is folding OK and the secondary computer already has the ancient stuff in it so everything now ready for the off, many thanks
  4. RedFlames
    23 Apr 2009
    It all works so you're on up on me right now... good to hear you're all set and sorted though :thumb:
  5. mikemaher205
    mikemaher205 What's a Dremel?
    14 Aug 2011
    Sorry to hijack your post, but I want to run a GTX 660 and a GTX 285 on the same motherboard... Is this possible?
  6. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    They'll co-exist but unless you can make sure that they don't try to Fold each others WU you'll have all sorts of problems. It is possible, someone on here has done it, but I don't remember who.
    Basically it isn't advised to mix different generations of cards.
  7. Taffy
    23 Apr 2009
    No Problem mikemaher
    Two things, 1) make sure that you give them different numbers, and 2) give a slight delay between starting them, I am using 2 x 275's
  8. mikemaher205
    14 Aug 2011
    Ok, thanks. I wasn't sure that a 200 and 600 series would work together in the same system without upsetting the OS.
  9. steveneedle
    steveneedle Minimodder
    2 Jan 2010
    hiya
    I am runnin a 460 at the moment but want to stop as its my main gpu...
    could I add a 450 in my spare slot and just fold on that one?
  10. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    yes
