i7 2700k
Discussion in 'bit-tech Folding Team' started by steveneedle, 30 Jun 2013.
  1. steveneedle
    steveneedle Minimodder
    2 Jan 2010
    hiya just wondering is there any benefit me getting the 2700k over the 2600k for folding?
  2. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    None if you plan on overclocking it, a lot of 2700ks I have seen don't overclock as well, as if there is more issues with the wafers they are made from.
    If you are doing no overclock, then the 2700k would be slightly faster as it has a 100Mhz bump.
    But you would have to be daft to not OC it when folding, the 2600k folds damn well with a good overclock.
  3. Zaim
    Zaim Minimodder
    18 May 2010
    Depends, do you already have a 2600K? if not then I'd go with a 2700K, I've seen plenty that are very close together in terms of price.
  4. steveneedle
    2 Jan 2010
    at the moment im running a i3 2100.....so will be as high as I can go on my motherboard
    scan has the 2600k for £260 an ovrclockers have the 2700k for £230
    or do I go for a 2500k from ebay for about £120
    im running windows 8
    8gb mem
  5. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    id have a look on the marketplace here for a 3770k they have beeing going for around £190. There are some 3570ks on here around £110-120 mark but the HT on the i7s are better for folding.
  6. steveneedle
    2 Jan 2010
    but I think those cpu wont run on my mother board unless I do a bios flash.....an not sure on doing that
  7. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Flashing the bios is very easy, what board are you on?
    And I would recommend just buying used off the marketplace, will save you a fortune. Have bought and sold many CPUs on here myself.
  8. steveneedle
    2 Jan 2010
    its a msi h77ma-g43
  9. MrGumby
    27 Apr 2009
    being a H77 chipset probably wont even require a bios flash.
  10. steveneedle
    2 Jan 2010
    how will I know if im running a bios that wont need changing?
  11. steveneedle
    2 Jan 2010
    well ive used msi live update an I think ive put the bios to the latest version...is there anywy off checking?
    if I ordered a i7 3770k id wanna be sure it will run first time on my board
  12. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    Running cpu-z will tell you what bios you are on.... will also appear on the post screen i believe
    sent from me phone :)
  13. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
  14. steveneedle
    2 Jan 2010
    thanks guys
    I got a 2600 in the end but I cant overclock with my board
    so im on the lookout for a new board now
  15. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Don't worry about spending too much cash, any P67 or Z68 or Ivy bridge equivalent will do the job fine. My cheapy Asrock Pro3 board will hold my 2600k at 4.8Ghz stable.
  16. steveneedle
    2 Jan 2010
    I was going to go for a z77...but cant remember why now
  17. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Future upgrades possibly. But honestly, don't go crazy. Almost any board that supports overclocking will hold a decent enough speed for a folding rig.
