I have a couple of the vandal switches and two bunches of 4 cables I suspect that one will go to the power on connection and the other to the reset. Two of the wires will connect to the reset and power and the other two I guess are for lighting the switches. I have no idea how these should be connected. The connection wires come with two yellow connected to a sing plastic connection the other two wires are one red one black and are each connected to a single plastic connector. I found this http://forums.bit-tech.net/showthread.php?t=256446 but am not really any wiser. Help sought on how to connect the vandal switches both ends.
Got it with a bit of trial and error and help here http://www.kustompcs.co.uk/acatalog/info_3359.html
