Modding Cooler Master Seidon 120M fitted to MATRIX GTX 580 (LLC cooler mod)
Discussion in 'Modding' started by Guest-16, 25 Nov 2012.
  1. Guest-16
    Guest-16 Guest
    So I was having a chat with the guys at CM and wondered if this would work. Turns out the 120Ms mounting holes are verrry close to that of the GTX 480/580/680 and a few zip ties later it all holds down pretty firmly. I'm getting 49C full load (no OC yet), with my case side panel fan cooling the VRMs. If I had more tools, cutting 4 short ~1cm strips of steel with 2 holes should extend the mounting holes, as a less ghetto solution.
    Next I need to change the CPU cooler as the Fenrir gets in the way :/ and I wish the HAF-X had mounting holes in the floor for a the fan and rad so it could be neater.
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    personal experience tells me that it won't remove alot of heat. But its a nifty little trick to pull :)
  3. Ra6
    Ra6 What's a Dremel?
    4 Nov 2012
    49C full load is quite impressive! Good job! ;)
  4. Guest-16
    Guest-16 Guest
    Howso? :)
  5. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    too bad it cant be pulled with a 560..... :(
  6. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    >Too bad it cant be pulled with a 560
    why that? no problem as long as there holes in the GFX's PCB. zip-ties good for mock-up or temporary solution. for long time run one could make some "adapter"
  7. Parge
    16 Jul 2010
    Well, as above, 49C under full load appears to show that it has knocked about 30C off the temps.
    Agreed. That's only about 10C less than you'd get with a full WCing setup. Admittedly, that is the core temp, so OCing will be the real test (as your VRMs will start to get nice and toasty)
    It can in fact, I've seen it somewhere *attempts to track down link* :D
  8. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Only thing im wondering is whats keeping those VRM's, memory etc cool?
  9. Guest-16
    Guest-16 Guest
    HAFX side panel fan.
    I actually had to remove the pump as it didn't like being sat upside down :(
  10. Vetalar
    21 Jun 2011
    tip for manufacturers: for the GPU LCLC unit it's better to combine pump with rad. lower stress to GFX due to weight and vibration
  11. Stem83
    26 Mar 2011
    Or use a case with those upside down atx trays, window on the right side case panel thingys. lol
  12. Silent_Raider
    Silent_Raider What's a Dremel?
    20 Aug 2010
    Try a Silverstone Raven case so it's sideways instead of upside down?
  13. Guest-16
    Guest-16 Guest
    The high speed fans always cause an amount of vibration anyway tbh.
    Silent - yes any other orientation and it's fine. I've got it on the CPU now for a while.
  14. siliconfanatic
    10 Sep 2012
    the one problem is my 560 is factory OCed...... and i will soon be getting another one to bump it up to an sli rig:naughty:... if a amd mobo can run sli:eyebrow::confused:.... are there any real good coolers for the vrm's and such? cause by god when i put this thing on water it sure as a modder is nuts is gonna have good temps and lots of radiator coolnes:D
  15. Vetalar
    21 Jun 2011
    siliconfanatic
    no problem here IMHO. as long as there zip-ties and duck-tape... :D
  16. Psyance
    Psyance What's a Dremel?
    6 Dec 2012
    This starts my brain ticking.:idea:
  17. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    Looks impressive, and 49 degrees is better than most heatsink combinations.
    More companies need to make enclosed loops for graphics cards, in my opinion :)
