Other Ordering from scan tomorrow, need tim
Discussion in 'Hardware' started by numanoid, 2 Aug 2011.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Hi guys
    im ordering some parts from scan tomorrow so might buy some more thermal paste, need to know what is the very best Tim....is it still artic silver 5
    thanks guys
  2. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    artic mx-4
  3. numanoid
    numanoid Modder
    26 Apr 2009
    So that is better than artic silver 5 mate
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I think most people have given up caring TBH, at least I have. Arctic Silver 5 is pretty good, that's what I bought last - but I can't remember if used it or used the stuff that came with my Noctua HSF... I'm getting old. :p
  5. Sagman76
    Sagman76 What's a Dremel?
    28 Jan 2011
    Used to use as5 but I believe it has 200 hour running in and to be honest it's quite thick. Ordered mx2 from scan for £3 and very pleased and no run in time. I have 212+ so didn't spread as used thin lines down each copper line but it's a nice consistency to spread
  6. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    Shin etsu is the best, but Scan don't stock it!
  7. numanoid
    numanoid Modder
    26 Apr 2009
    Cheers guys
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    the difference between best and worst will be 3-5C, so it hardly matters. It was discussed in the last hardware podcast, it's more about the amount and how it's applied that makes the difference...
  9. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Yeah sometimes people choose TIM based on how easy it is to apply. I have two on the go at the moment, MX-2 and Thermalright Chill Factor - the Thermalright one is much easier to apply and is virtually identical in performance.
    If I had to suggest one for convenience of application it would be the Zalman stuff - it comes with a brush and is very good stuff.
  10. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks lads, ill have a look at what scan have to sell and choose one
    take care all
  11. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    mx2, definately not mx3
  12. penryn 2 hertz
    10 Jun 2010
    i use mx-2 myself but soon as that runs out i will be buying mx-4
  13. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Soon I will be using rubbing alcohol to clean a i7 sandy and the used surface of a h80, I have some arctic silver 5 and id like to know what is the best possible way to apply this and fit it together.
    do you put a small blot in the middle and use some card to smooth over a thin layer.
    How thing should the layer be, is it a case that the Tim just basicly covers the pits in the surface of the CPU so a really really thin layer is required.
    Obviously i have the reference amount that shipped on the top of the H80 which was basicly like a square and about 1mm thick.
    Any thing to avoid, obviously to much is a big no no.
  14. zulu9812
    zulu9812 What's a Dremel?
    21 Oct 2010
    Some TIMS are quite a thick paste and are difficult to apply, so here's a tip: run the tube (closed) under a hot tap first.
  15. stefan442
    stefan442 Minimodder
    14 Mar 2011
    a rice sized dot, let the cooler spread the paste!
  16. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Or put it in your pocket for a bit and let your balls warm it up - shouldn't take long with the current temperatures...
    ...or ask the other half to help "warm it up"...
    :D
  17. zulu9812
    21 Oct 2010
    I like the cross method myself
  18. Kemp
    Kemp Minimodder
    22 Jul 2011
    I put a couple of blobs in different places and then use a small piece of laminated card (there's inevitably some in the packaging from one component or another) to spread it thin. Of course, it takes forever as I try to get it perfect. I eventually give up and just use it :hehe:
  19. SonnyJim
    SonnyJim Minimodder
    19 Jan 2011
    What's wrong with Mx-3?
  20. faugusztin
    11 Aug 2008
    WTF you guys overcomplicate the whole process. One small blob in the center, put the cooler on it, move the cooler a little bit, fix the cooler. Spreading it thin is pretty useless work if you ask me.
    MX-3 is hard to apply.
