Modding advice on cutting acrylic
Discussion in 'Modding' started by PurE GaminG, 21 Jul 2012.
  1. PurE GaminG
    PurE GaminG What's a Dremel?
    24 Feb 2012
    hi guys i need your help once again
    guys i wish to cut some mirror acrylic 1/8 =3mm , white true LED 1/8 =3mm and s-lux 8mm
    the only tools i have are jigsaw and plastic cutter i cant afford a brand saw or table saw.
    so could use the jigsaw with fine tooth blade to cut a square notch out of the acrylic and is there specially way to cut mirror acrylic.
    some pic of what to accomplish .
    this the square i was talking about:
    [​IMG][/URL] Uploaded with ImageShack.us[/IMG]
    this is the acrylic cutout in the cosmos 2 case
    so guys how could i cut these acrylics using jigsaw like i said cant afford any other tools or if you any other cheap recommendation plz do let me know
  2. Cheapskate
    13 May 2007
    Mirror acrylic is usually extruded, so a jigsaw will melt it. Your best bet is to file it.
  3. japala
    japala What's a Dremel?
    8 Dec 2001
    I've found that it is better to use a blade with larger teeths rather than fine. The fine teeth one cuts slower and removes smaller pieces from the acrylic thus heating it up more -> melting. Depending on the thickness of the material there must be a sweet spot on what kind of teeth size and teeth spacing is ideal but for me almost any blade meant for wood has worked great...
